Meridian Explorer² Impressions Thread
Sep 8, 2016 at 11:20 AM Post #631 of 1,003
yangian
  If you charge the Mojo completely, and leave it plugged in, the charging circuit cuts off. If you then play for a while the battery level drops, and charging starts up. This happens when the battery level drops by 0.2V.
This method stops the Mojo becoming hot when charging and playing. It only gets warm, or hot if the ambient temp is high. It doesn't get so hot because charging is constantly switching on and off.
There is also the potential to be able to use the Mojo away from desktop. Like e.g with a phone and headphones, sitting in a chair.
Anyway back on topic, the Mojo is the better DAC than the ME. However the ME is still a good DAC. I have not sold my original ME and never will.
If you read back through the thread I did a side by side comparison of the Mojo vs ME(1). Basically I found the Mojo has a slightly wider image, and a taller image. The Mojo was not only wider but I heard instruments at the sides which I overlooked with the ME sometimes. The ME was smooth by sound richness. The Mojo was smooth by clarity and effortless detail. To be completely honest, it took me a long time to graduate fully to the Mojo. I found the ME still had a lot to offer, even though the Mojo had more detail. When I found bit-prefect the gap between the two DACs widened.
The ME(1) is a good warm smooth DAC that lacks just a little control and organisation sometimes. The Mojo is a DAC which is a bit 'out of this world'.
Whichever DAC you use though, I strongly recommend playing your music files bit-prefect whenever you can.
What do you mean of "bit-perfect"? Thanks.
Sep 8, 2016 at 2:00 PM Post #632 of 1,003
pkcpga
NYC or Northshore Massachusetts
I switched to the mojo as well, it definitely has better instrament timing and separation. Just a better DAC, if you rest the mojo on its narrower side while charging and listening it does not get too warm or hot. I wish chord came up with a small portable battery-less DAC.
Sep 9, 2016 at 5:21 PM Post #633 of 1,003
TadMorose
Canada
  WARNING?!
I just had my Explorer replaced with a brand new one after it completely died one day.
It was in min condition and had been used on only one pc, stationary, never moved, still in plastic wrapping.
Now when I returned it they had just gotten one with the exact same issue. Just dead one day.
Did anyone else have this happen? I'm afraid this brand new one will die one day and maybe I'm better off just selling it?
It happened to me. I had my ME2 replaced twice.First two units were from the same batch distributed by a company in Quebec, Canada. The 3rd one was sent from Georgia and no problems with it so far (knock on wood). Both units that died were getting really hot during operation and I think that's what killed them eventually.
Sep 19, 2016 at 12:43 PM Post #634 of 1,003
Josh83
Just thought I'd give my two cents here.
I've had my E2 for more than a year now without any issues. My main DAC is a Yggy, and I use the E2 three or four days a week when I'm in my office at work.
The E2 remains the best sounding portable DAC I've tried. Recently, I bought an Apogee Groove, only to sell it a few weeks later. Soundwise, it just didn't compare to the E2.
I'll be receiving a Fulla soon to compare that with the E2, also. I've debated checking out the Red DragonFly, too, and maybe I will at some point.
I'm not interested in portable DACs with batteries. So I suspect that, unless/until Schiit makes a multibit portable DAC, the E2 will remain the best sounding of the bunch.
Sep 19, 2016 at 12:56 PM Post #635 of 1,003
pkcpga
By the sound of it multibit will never be portable since it needs to warm up and run its course for hours to a day before it sounds normal. Schiit offers a portable DAC amp but not with multibit, also not very good DAC in it right now.
Sep 19, 2016 at 9:40 PM Post #636 of 1,003
yangian
What headphones do you use?
Sep 27, 2016 at 1:54 PM Post #637 of 1,003
Josh83
I tried both with a variety of headphones, but the main closed cans were NADHP50s and the main open cans were Philips SHP9500s.
Both DAC/Amps sounded good with the NADHP50s, though the E2 still sounded better. The biggest difference was that the E2 had a more natural, rounded presentation, especially on the bass, whereas the Groove had the (fairly typical) Sabre sheen, which makes electric bass guitar sound a little flatter and more like a synth bass than it should.
There was an even bigger difference with the SHP9500s. I assume it had something to do with the Groove's constant-current amp. The EQ just sounded "off" with the Groove and the SHP9500s. The upper-mids were too accented, emphasizing sibilance on vocals, etc.
Sep 27, 2016 at 11:06 PM Post #638 of 1,003
yangian
Thank you for the information!
Sep 28, 2016 at 10:35 PM Post #641 of 1,003
theveterans
Santa Rosa, Laguna, Philippines
For Mac OS X, you need an app that uses its own audio plugins such as Audirvana+ to deliver bit-perfect stream to the DAC.
Nov 19, 2016 at 9:45 PM Post #642 of 1,003
Hal Saunders
My Audio Technica AD900 headphones are spec'd at 100db sensitivity and 35 ohm impedance. Would this fall easily into the Explorers comfort zone? Also, everything I've read makes the explorer seem a gorgeous, valve like listen which is my preferred sound signature by a mile. Would this be a better suit for me than the Audioquest Dragonfly Red, which from all accounts is a great item but maybe just not the sound I prefer? As a standalone Dac, I gather that the explorer is as good as most mid price Dacs, any comment on this most appreciated, the unit will get probably equal time as a DAC as feeding headphones.
Thanks,
Nov 20, 2016 at 10:43 PM Post #643 of 1,003
peterinvan
Vancouver, Canada
Thanks,
My Explorer2 can drive the Audeze LCD2, so no power issue.
The advantage of the Dragonfly Red is it can be driven straight out of an iOS device.
So... The Explorer2 is now my DAC for my tube amps. I have the iPurifier and iUSB power supply feeding the DAC. Lovely sound. Patiently waiting for MQA from Tidal.
Nov 22, 2016 at 6:40 PM Post #644 of 1,003
musickid
U.K.
im trying to choose between an oppo ha1 amp / pm1 cans vs brooklyn amp/dac which is mqa ready. im really liking the oppo combo after trying it. i do listen to tidal hifi mainly and would like to be ready if mqa arrives. if i go for the oppo system i would get an explorer to use as dac only with oppo ha1 amp therefore covering mqa. i can't foresee how much of tidal will be mqa. if its soon maybe the brooklyn would do but then i would have to source the right cans. the oppo combo is ready to go and great. how good basically is the expl.2 as a dac only to external amp? many thanks.which of the above two options would you all go for.
Jan 5, 2017 at 3:01 PM Post #645 of 1,003
peterinvan
Vancouver, Canada
MQA streaming!
Tidal MQA works through my Explorer2, but only through ROON...?
I tried the new Masters using the Tidal Windows desktop, but could not get my Meridian Explorer2 to light up. So I tagged the new MQA albums in Tidal, switched to Roon, re synced to Tidal. Now I get the three LEDs to light up on the DAC, and play MQA.
This the Roon path...
The LEDs on my Meridian Explorer2 show Blue/White/White.  Is this correct?
My first impressions are that the MQA stream through Roon to the Explorer2 sounds better than the "MASTER" decoding through the Tidal PC app, e.g. on
Moondance (Van Morrison)
American Beauty (Greatful Dead)
Buena Vista Social Club
