koto-in
- Sep 20, 2005
The maximum current output is determined by the op-amp, in this case 45mA. The amp will draw only as much current as it can utilize regardless of the amount of current available. The specs say that the mean uptake in low current mode is 7mA and in high current mode 18mA.
Originally Posted by Thurston Moore /img/forum/go_quote.gif Does the current capacity of the power supply effect the performance of the MOVE as long as you have one that handles more than 50 mA (as recommended in the user manual of the MOVE)? I have found power supplies that handles far more...everything from 500 mA up to 5,0 A at 12V. Does it matter? Are the ones being able to handle a higher current making the MOVE perform better? |
