Meier Corda Aria no gain switch, a problem as i needed it on Bithead ?
Jun 26, 2007 at 1:34 PM Thread Starter Post #1 of 5
lerio
Like the title say, as i nedded to switch gain button with my Total Bithead it will be a problem if i don't have this function on Meier Corda Aria ?? [size=xx-small]if i do the jump to Aria [/size]
Jun 26, 2007 at 4:26 PM Post #2 of 5
I have an Aria and it performs well with all phones. I tried it with an RS-1, K701, HD600, and Etymotic ER4S. While it performs well with all of them, it does a little bit better with more sensitive headphones. I bought it to use it with my ER4S (100-ohm) in the office and it does its job splendidly.
Jun 26, 2007 at 4:30 PM Post #3 of 5
To be more precise my question was does Corda Aria will give me same (at least) power then Total Bithead with gain switch select to On ?
I'am not pro enough to compare spec of both, i just know that Bithead with gain switch Off was not enough
Jun 26, 2007 at 6:01 PM Post #4 of 5
I am sorry as I am not going to be much help here. I only had an older Bithead withouth the gain switch and for a very short while. Aria had significantly much more power.
Jun 26, 2007 at 6:58 PM Post #5 of 5
That's rather a good point but i'll need to be sure before invest, any Pro here can confirm ??
