shotgunshane
- Sep 25, 2010
Sounds promising.
Been listening to these on and off for a day now. Some very important things I've noticed.
- The silver-plated cable is arguably of much higher quality, and it considerably extends the FR on both ends -- bass dips deeper and highs reach further. HOWEVER, I find it to tip the scale of harsh and make the P1 too treble-heavy to listen to. I have five total MMCX cables (partially by accident), and all four other ones "reduce" the extension a little, but I only find it to impact the treble, which is a good thing for me. Basically, the silver-plated cable does +5% bass, +20% treble.
- The micro-detail and note persistence the P1 is capable of is STUNNING. Even better than my Etymotic ER4S. It's so much easier for me to hear background lines in complex passages with the P1 than in any other IEM I have.
- The treble-extension is extremely flat and has excellent resolution.
- Very comfortable and easy to wear, all the time.
- The included silicone tips fit great; however they enhance treble too much too. I was having a bit of trouble with treble with silicone + silver-plated cable, I can tell you that!! But the Comply tips work much better. It's not a matter of "softening" the treble; the Comply tips "stop enhancing" the treble compared to the silicone.
Maybe try to go to the next larger size silicone tip? I actually switched to using UE900 silicone tips. They have a bigger/wider cap. It's all about the seal
I made sure I had a perfect seal. It's simply the character of silicone versus foam.
How do they fare with metal? Would they fit under a motorcycle helmet. I had the MEE Audio M-Duo's, and liked the sound.
I wonder how P1 compare to Audio-technica ath-IM02 ? I was thinking about buying im02 but since i saw this review I'm not very sure which one to buy now.
I owned the IM02 for about a month. Don't bother. They're fairly similar sound signature, and the P1 is more competent in literally every way. They're not even in the same class. The P1 exceeds the IM04 which I had for about 3 months.
Hmmm, this seems promising. I am in the market for a neutral-ish iem as my gr07s recently died, was debating the im02, ue900, Titan 1, re400, fidelio s2anything under $500 really and I stumbled on an inner fidelity video about these. the above impression about killing the im02 has me very very intrigued. How do these compare to the GR07?
