MD Users: I need recommendation for powered mini-mic / bootleggin'
Jun 26, 2003 at 2:43 PM Thread Starter Post #1 of 4
austonia
I actually want a mic for use with MP3 recorders/encoders, but MD users have been bootlegging for years, so I figure someone here might have a quick answer. I know I need a powered, sensitive mic, and something stealthy. But, I don't know where to get started, what store to look at, product differences, etc. Cost not much of an issue. TIA
Austin
Jun 26, 2003 at 6:24 PM Post #2 of 4
Check this place out: www.soundprofessionals.com
They have quite an immense faq regarding all the different type of mics they sell, i definitely plan on buying an audio technica mic soon for some summer concerts
Jun 27, 2003 at 1:38 PM Post #4 of 4
I'll third that nomination.
I purchased a mic from SP that I use with my MD recorder. Just make sure you take to Chris about what you are going to use it for. I had to buy a battery for the mic since my line out does not have a high enough gain for the mic I bought. I am thinking about buying one of his small mic pre-amps so I can use them in more varied situations. Btw, the mics work great.
gb
