A.Thorsen
- Feb 26, 2006
Bitstream: CEDIA: McIntosh's SACD/CD Player
Not cheap, obviously, but considering all that it does and such, this might fill a void for some folks around here, especially if you kill a bunch of birds with one stone like what this thing does.
What? You thought SACD was dead? How wrong you would be. At least at the CEDIA Expo, SACD was making a strong comeback showing. Maybe higher-end installer types are presenting more demand than lowly big-box store customers. In any case, the high-end audio format is certainly alive and well on the Expo floor in Denver. Case in point, the McIntosh MCD500 SACD/CD player is their flagship model, joining the MCD201 and MCD301 players. It features two selectable digital inputs, coaxial and optical digital inputs, fixed and variable balanced outputs (up to 6 volts), dedicated headphone amplifier with level control, and die-cast disc tray. Also inside, you'll find four 24-bit/192-kHz D/A converters per channel arranged in a differential balanced configuration. Of course, all clocks are phase-locked looped. Data is read from the disc at twice the normal rate. The glass front panel is illuminated by a combination of custom-designed fiber optic light diffusors and LEDs. An illuminated remote control is included The MCD500 will retail for a mere $6,500. |
