soundisee
- Nov 24, 2012
I currently have an MBox 2 interface http://www.zzounds.com/item--DGDMB2 and was wondering if anyone knows if it has enough power to drive headphones like DT 880 250 ohms?
The specs are not too detailed but the 6 mW maximum power into 50 Ω does not look good by itself. Maybe it has rather high output impedance, and then with a 250 Ω headphone the power output could be similar, but 6 mW is not much anyway. In any case, rather than guessing, you should probably just try it and decide yourself whether there is enough power. If not, a FiiO E11 (~$65) or a good cMoy for a similar price would fix the problem.
With the FiiO e11 would I just plug my headphones into the amp and have the amp plugged into my mbox2 headphone input?
