max out meta
post-184565
Thread Starter
Post #1 of 19
LTUCCI1924
HI: I just ordered a maxout meta from JMT. Does anyone have one if so how do you like it. I would like to use my 580s sometimes in it but will mostly be using my koss portapros in it for portability. I had the 2-9 volt cmoy amp and really liked it but when I opened it up there was not a lot of stuff inside it. Then JMT showed me some pictures of the open maxout meta and wow there was all kind of stuff in it. So any feed back on the maxed out meta would be very appreciated. Thank you.
PS
I mean sound quality
strength(power)
clearness
cleanness
and overall quality of amp.
JMT said that this is the best meta that he makes.
post-184578
Post #2 of 19
timoteus
If you liked your CMoy then I think you'll really like your new META42.
JMT built a META42 for me in the following configuration:
AD8620 op-amp
Alps Blue pot
Elna Cerafine PS caps
Vishay resistors
dual stacked 2001 buffers
Cardas jacks
Biased to Class A
Locking Neutrik jack
Blue LED
I don't know if this is the maxed out version you ordered but I'm sure it's pretty close.
The sound quality is crisp and clean. Silent background. Very fast and a great build too.
I'm using the Ety ER-4S and have plugged in my HD600 a few times to try them out. These are similar to what you will be using so I think you'll have similar results. I think the limiting factor for sound quality in my setup is the PCDP. If I hooked this amp up to a high quality source who knows...You should be pleasantly surprised and happy with your new purchase.
Edit:
I have found that I get the best sound by turning the volume down on the PCDP so that I can turn the volume up to 1/2 or 3/4 on the amp.
post-184579
Post #3 of 19
LTUCCI1924
timoteus
Thank you for your post.
post-184585
Post #4 of 19
RVD
I have a Tangent-built Meta42 and I love it. The amp has great detail, bass, soundstage everything. The amp has sounded excellent with every headphone I have plugged in to it and it has driven everything cleanly and loudly. This is the configuration of my amp:
Burr-Brown OPA627
4x stacked EL2002 buffers
Alps Blue pot
ELNA Cerafines 470uF/25v
Wima MKS-2 caps
Biased to Class A
Internal Liner Power Supply
Vishay Resistors
I hope this helps.
post-184645
Post #6 of 19
timoteus
If you send Tangent, Eric343, or JMT a private message I'm sure that they would be happy to give you a price quote and/or a list of options.
post-184681
Post #7 of 19
puppyslugg
LTUCCI1924:
JMT didn't provide any details on the maxed out META he's building for you?
post-184686
Post #8 of 19
Aboogwa
Funny, I wanted to order a maxed out meta, but JMT wouldn't respond to my PMs sent about a week ago after the initial one with the price quot and options... and eric and tangent seemed to be busy
Maybe there's a bias toward veteran members?
/EDIT oops what a coincidence, just seconds after I posted this I got a PM from JMT
post-184687
Post #9 of 19
RVD
Aboogwa, JMT is usually very busy and it sometimes takes him a few weeks to respond to pm's. I am sure he will respond to you soon.
post-184688
Post #10 of 19
LTUCCI1924
Aboogwa
HI: It took JMT 2 weeks to get to me. A lot of people want an amp built. E-Mail him again. IT seems that all 3 of the amp builders are very busy.
post-184691
Post #11 of 19
LTUCCI1924
puppyslugg
Yes he did but I foget it all. Just the best of everything.
post-184692
Post #12 of 19
Aboogwa
Originally posted by LTUCCI1924
Aboogwa
hmm... I see... Guess these DIY amps are hard to obtain..
post-184697
Post #13 of 19
Possum
You could try to build one yourself.
post-184711
Post #14 of 19
Aboogwa
This doesn't factor in to the current situation since like to many others this is not an option for me
post-184793
Post #15 of 19
HighwayStar
Won't excrete urine on your holiday (unless you do so to his first).
Not at all. But you need to realize the individuals building these do it as a side line. They have day jobs and families like everyone else
It's definitely worth the wait though...
