Matrix Mini-i Balanced DAC+HP amp
Feb 6, 2011 at 10:57 PM Post #631 of 1,054
epocs
A couple questions about this unit:
1. How does this sound DAC-wise to the HDP or Pico DAC?
2. If I have a pair of self-powered speakers that do not have volume control, and also a headphone amp that the other outputs go to, can I have one of the outputs be fixed and the other output be variable? This way, I could control the speaker's volume through the matrix, while not adjusting the volume of it going to the headphone amp.
Feb 7, 2011 at 2:00 AM Post #632 of 1,054
T.IIZUKA
Changeability and fixation can be set.
At PRE-MODE, the analog output becomes changeable.
Manual is here.
http://www.matrix-digi.com/english/fwzc.asp
Feb 7, 2011 at 2:15 AM Post #633 of 1,054
epocs
So this means that both outputs can either be variable or fixed, but not one fixed and one variable right?
I would want to plug the variable one directly to my speakers, then the fixed one to my headphone amp. This way, when music plays I can put the volume to 0 on my variable so the speakers don't play and yet the headphones will play.
Either that or I would want only one output to be on at a time- and I'm guessing that cannot happen right?
Feb 7, 2011 at 7:59 AM Post #634 of 1,054
Ph1lerAudi0
Exactly. The Power on sequence that T.IIZUKA described determines the character of the whole unit. The Matrix mini I can either be a straight DAC (fixed) or a headphone amp (variable.) Never both.
By the way, T.IIZUKA, I am most jealous of your self made blue label matrix. Any plans to replace the transformer?
PA
Feb 7, 2011 at 8:54 AM Post #635 of 1,054
T.IIZUKA
PA
I just want a toroidal transformer.
Tough pitch copper is enough.
OFC is dread.
Feb 17, 2011 at 7:45 AM Post #637 of 1,054
bjrnrb
Hi.
I have some communication problems with the seller of my Matrix mini-i. I was wondering if someone could write that I mean in chinese.
I've tried to send him lots of mail and only get reply about the tracking.
Here's the message:
I need to get a new Matrix mini-i, because mine is broken. I've tested it for a couple of hours, when it suddenly stopped working. I've tried all the instructions, and it also smell a little burned. I'm hoping you could send me a new one, and that I can return the old one when the new is recieved. I also hope you could cover my postage fee that would be around 70$.
Best regards
Bjørnar Brandvik
Feb 22, 2011 at 12:53 AM Post #638 of 1,054
jtam
Member of the Trade: Tam's Audio (coolfungadget)
Not from me.
Hi.
Here's the message:
Best regards
Bjørnar Brandvik
Mar 2, 2011 at 5:15 AM Post #641 of 1,054
j0lly
I also get the No Sample error all the time.
Mine works perfectly, but if im turning on/off my speakers (xlr), or even just a light (!), I get the No Sample error.
And to clear it, its not enough turning the matrix off, I need to unplug/plug the USB to get it going again.
But serioussly, turning on a damn light? So im guessing ripple gets through, how is this not filtered in the power stage? Or does it get in through the usb?
Mar 6, 2011 at 8:23 AM Post #642 of 1,054
bjrnrb
That sounds really weird. Finally I will recieve a new Mini-i too ;D Maybe the voltage on the USB-ports are too high or something? Reply to me when you have found out the reason why the mini-i does that  :)
Mar 6, 2011 at 8:27 PM Post #643 of 1,054
Hellenback
2xPCM1795 for each channel!
USB accept 192k input, and can upsampling!
@ T.IIzuka
Why not go all out and use the PCM1792?
  Is the PCM1795 better than the PCM1796? I have the 1796 in my SACD, DVD-A player and it sounds exceptional.
Last question...are there any electronic parts you didn't swap/replace and how much did the mod cost not counting labor?
Mar 7, 2011 at 3:05 AM Post #644 of 1,054
T.IIZUKA
@ T.IIzuka
PCM1796 is installed in my CD player.  (CEC CD3300R)
DAC is variously tried.
I like sound of AD1955.
Remodeling to MATRIX is continuing now.
A part of the power supply maked a change of the other day.
Time and cost hang. It is made not to calculate. :p
Mar 15, 2011 at 12:28 AM Post #645 of 1,054
paul666
Hi,
I have one of these and when I send a dts/ac3 signal to it it does not mute the analogue outs so I get hissing through my speakers on my stereo amp.
The dts/ac3 signal does pass-thru OK and my av receiver gets it OK but unless I have set my stereo amp to home theatre mode so it is effectively a power amp and getting its signal from the av receiver as above hiss through my speakers.
Is this correct should it not mute the analogue outs when receiving a dts/ac3 signal?
It does this either it pre or dac mode.
Firmware 1.21
Thanx
Paul
