Schiit Lyr is a tube single-ended amp. It's like comparing apples and oranges. Any tube amp is colored IMHO.Anyone compared THX AAA 789 with Schiit Lyr 3? Although Lyr 3 is priced high.
Massdrop x THX AAA™ 789 Linear Amplifier - Impressions Thread
- Thread starter XERO1
flyte3333
Previously known as Em2016
- Jan 21, 2017
See the RCA to XLR Benchmark cable Yviena found. That's how it's done properly.
Your 1 side floating shield approach doesn't provide a separate path for CM current to flow. In your setup, CM current will flow in your star quad negative wire, adding ground bounce that'll manifest as noise/hum.
Check out the Benchmark RCA to XLR cable Yviena found. That's how to cover Ll the bases.
Hi Andrew,
Is this a typo on the Benchmark site:
"The separate connection from the RCA ground to pin 2 of the XLR provides a dedicated path for the audio ground reference. "
Should that be XLR Pin #3?
Because the description says:
"One half of the star-quad ties Pin 3 of the XLR to the shield of the RCA connector. The other half of the star-quad ties pin 2 of the XLR to the center pin on the RCA. The braided shield ties pin 1 of the XLR to the shield of the RCA."
From Rane:
Audiodoc
- Sep 15, 2011
My amp is working fine with SE outputs. Yesterday made a XLR silver cable for my HD650s. Whenever I increase the volume in any of the gain modes the overcurrent protection is activated and the red led is lit. I have not used the ground pin in the XLR male plug just pin 1 left positive pin 2 left negative pin 3 right positive and pin 4 right negative.
If you have a multimeter check that there's no continuity between any two pins. You may have shorted something when building the cable.My amp is working fine with SE outputs. Yesterday made a XLR silver cable for my HD650s. Whenever I increase the volume in any of the gain modes the overcurrent protection is activated and the red led is lit. I have not used the ground pin in the XLR male plug just pin 1 left positive pin 2 left negative pin 3 right positive and pin 4 right negative.
ReAlien
By some wicked twist of fate I have ordered both of them!Sounds like you are working towards getting the THX AAA 789. The amp must have the features you need of course. Do you need balanced output or pass through it´s a given not to go with the V200.
Long time since I had the V200 it had more of a v-shaped signature I felt but will not go into details more then it really does have a clear signature. And if you really liked it, it may suit you better. Of course, the only way to know is to get one and compare![]()
escalibur
- Feb 9, 2016
Any information when will this amp be available again?
AndrewM888
Member of the Trade: THX
- Oct 3, 2016
Good catch! Looks like a typo. You could email them to report it.Hi Andrew,
From Rane:
omniweltall
- Nov 13, 2016
@gtbrown50,
I see that you have both the THX AAA 789 and Burson CV2+. Which one is better? Can you provide a comparison please? That would serve as a good benchmark.
Cheers mate.
Cheers mate.
Audiodoc
- Sep 15, 2011
Yes you were right. One of the strands from the left positive was intermittently touching the ground. A few heat shrink and now it runs like a charm. ThanksIf you have a multimeter check that there's no continuity between any two pins. You may have shorted something when building the cable.
AndrewM888
- Oct 3, 2016
I hear a drop is imminent.Any information when will this amp be available again?
draculr
- Oct 23, 2015
Does anyone know if the RCA out is variable or fixed volume?
Fixed - it's a passthrough and it works even when the amp is off. It's not a preamp.Does anyone know if the RCA out is variable or fixed volume?
gtbrown50
@gtbrown50,
I see that you have both the THX AAA 789 and Burson CV2+. Which one is better? Can you provide a comparison please? That wold serve as a good benchmark.
Cheers mate.
I wish I could, but I purchased the Burson some time ago, pre-Schiit. As its a Dac and Amp, I never used just the Amp alone. When I went the Multibit route, Gumby then Yggy, the Burson was boxed and put on a shelf. Its still sitting on the shelf, and I'm planning on selling it after Christmas.
omniweltall
- Nov 13, 2016
I will compare it with the Burson CV2+ later, since mine has arrived.I wish I could, but I purchased the Burson some time ago, pre-Schiit. As its a Dac and Amp, I never used just the Amp alone. When I went the Multibit route, Gumby then Yggy, the Burson was boxed and put on a shelf. Its still sitting on the shelf, and I'm planning on selling it after Christmas.
Wil
- Apr 18, 2004
Just got it in the mail!
Paired with my Denafrips Terminator ( balanced ) - sounds excellent with either the Audio Technica ADX5000 or ZMF Eikon.
Just the amp to show that price is often not commensurate with performance.
