Massdrop x THX AAA™ 789 Linear Amplifier - Impressions Thread
Discussion in 'Headphone Amps (full-size)' started by XERO1, Mar 1, 2018.
99 100 101 102 103 104 105 106 107 108
110 111 112 113 114 115 116 117 118 119
  1. MacMan31
    Okay so I just placed my order for the THX 789. I was thinking about purchasing the Balance Grace SDAC but I noticed it uses the same DAC as my Fiio K3. Could I just use the 3.5mm line out on my Fiio K3 into the THX 789 RCA inputs?
  2. Cirkustanz
    Yes.
  3. MacMan31
    Hmm okay. Well I figured out that the line out on the Fiio K3 is adjustable by the volume knob. Doesn't that mean it's a pre-out? Either way what would be the best volume level to set the Fiio K3 to when using it with another amp such as the 789?
  4. Th3Drizzl3
    is the fiio balanced? i can say first hand the difference running the 789 balanced is pretty huge. i dont have that fiio so im not sure.
  5. Th3Drizzl3
    im REALLY surprised the drop is still going i though for sure they would have sold out by now
  6. MacMan31
    The Fiio has a balance headphone jack. A 2.5mm jack. But I'm talking about the line out output on the back of the Fiio K3. That way I can use only the DAC in the Fiio K3 and pair it with the THX 789.
  7. RestlessZombi
    Fiio describe the Line out as "Adjustable" which does indicate its a Pre-Out and not real Line out. You need to disconnect the headphones to use it and I would then just Max the volume. Check for distortion in the sound but you should be ok, if so just lower the volume a little.
    Balanced inputs would be noticeably better but you don't want to use the headphone out as the point of line out is as a pure signal without the added colouration you get with things like Bass Boost for example.
    Just use a quality 3.5mm to RCA Input.
  8. prymortal
    Good spotting i actually didn't notice that part & I am part of that drop.
  9. Trunks159
    Dont know all the specifics of Drop but they're branded/marketed as Drop + THX 789. Just like their Massdrop x products (Like Elex and 6XX), its different than a drop, I think their here to stay for a while due to the high demand ( I mean they'll run out at some point but I'm sure they have many more than last time)
  10. kumar402
    Finally drop made sure whoever want to buy this amp get their hand on it. Drop still active and almost 4.5K amp sold since yesterday. I guess with new label the number started from 1.
    It will curb the inflated price of this amp in ebay and all other second hand market place.
  11. savaloco
  12. savaloco
    Yep, wonder how many cancellation requests will be made by folks who had ordered multiple units to try and cash in on the trend?
    What makes this amp attractive is its' retail price. Going north of $600 iopens up other options in the used market. I saw a used unit go for $680 USD on ebay.... nuts!
  13. Marlowe
    I'm pretty sure that the 4.5K number is the total number of amps sold over all drops, not just the currently active one. If you look at the number sold for other items that have had numerous different drops over time (like the 6XX, 4XX and the Fostex headphones) and that is clearly how it is done.
    Currawong likes this.
  14. savaloco
    Nope... only 41 units sold when I purchased mine.
  15. alpovs
    No. When I received the notification and opened the site I saw "126 sold".
    Now I see 4,4k sold and it hasn't changed since 5-6 hours ago. Looks like whoever wanted it got it.
