Massdrop x Sennheiser HD 58X Jubilee Review & Measurements
Discussion in 'Headphones (full-size)' started by jude, Dec 20, 2017.
213 214 215 216 217 218 219 220 221 222
224 225 226 227 228 229 230 231 232 233
  1. rhiga
    My portapro is 13 years old and still works, i bought a ksc-75 and the left driver died in one week lol.
    Sharpty likes this.
  2. Seazer
    So what EQ have you settled on for your 58X? Are you just using the Oratory one found on Github thats in your signature? I saw earlier that you were making some edits to the Oratory one, have you done any more changes? Someone mentioned a mod 1.1 version or something, but the only one linked in this thread is your original personal edit, with the low pass and high pass filter etc. Can you link an update? Your signature just links to the github so I was wondering if you just settled on that. I did like the edited one called Mod 1 that you made though, I think it sounds good.
  3. Sharpty
    Ever since I found the more precise EQ settings on the AutoEQ github, I've just been using that. I still think there's room for improvement but I haven't had much time in the last few days to listen. Glad you're interested and liked the EQ settings tho, I will hopefully have an updated one here soon.
    Don't be afraid to tweak some things yourself. It helps to look at the response graphs to get a good idea of what you might want to boost or cut
  4. Seazer
    I took off the clips on the KSC75 and attached them to the Porta Pro since I find the clips so comfortable and I like the Porta Pro sound so much more than the KSC75
  5. JoshG1217
    How do these compare to DT 880? I had those and found them decent, but just okay, ultimately and returned them.
  6. TheRH
    What stock Sennheiser pads fit the 58X?
  7. caracal
    Thanks everybody. Guess I could buy both the HD58X's and Porta Pro's with yaxi pads :smile_phones:
    annasoh323 likes this.
  8. WilliamLeonhart
    I don’t think they have anything in common. The dt880 is dry and utterly uncoloreed. The HD58x has smooth mid-ranges and plenty of bass (not bassy headphones, though).
  9. JohannLiebert
    With 3,5mm hole felt mod the hd58x gets less warm yet smoother.
    Very similiar to HD660s ( which I had for one week) with better subbass-extension. If the HD58X performs 90% of HD660s, then with said mod it is now 98-99%.
    What a steal this headphone is!
  10. Seazer
    In my opinion that mod distorts the bass a bit, I got what sounded like some mid bass resonance when I tried that. the akg k240 foam pad mod where you put the pad foam side down (not cloth side) with no hole over the magnet might work better. I haven't tried it yet. The EQ found in this thread is what I have found made it sound the best so far though. I also wonder what dekoni sheepskin pads sound like on these phones
  11. TheRH
    I am one who like the 58X in Stock form, or rather not modding the actual drivers. I will be changing the cable to the stock Sennheiser one though soon to get rid of the need 1/8" to 1/4 " adapter.
    Tuneslover likes this.
  12. Seazer
    I'm getting a balanced cable for these so I'm excited for that
  13. TheRH
    If I go from a Schiit Stack (Magni 3/ Modi 2), I might got to a balanced setup down the road as these can do it. :D
  14. J Mirra
    Thanks for the heads up on the Yaxi pads, I use the PortaPro for gaming as they are so pin point accurate using a mixamp with dolby. I am looking forward to hearing them with the upgraded pads.
  15. VRacer-111
    Pretty much fully agree with the review Yaxi has linked:
    https://theheadphonelist.com/yaxi-ear-pads-for-koss-porta-pro-review/
