Massdrop x Liquid Carbon X Discussion
post-14330177
Post #166 of 464
thebkt
Toronto
Toronto
The LCX manual directly states that it is not designed to be left on for long periods of time once burned in.
I'm going with the official direction as opposed to speculation here.
I use my LCX at work and turn it off every afternoon.
post-14331007
Post #167 of 464
Bazirker
Finally got some more time on the LCX last night. I think it's still evolving some. I originally didn't find the LCX and HD6xx to be the best of matches. But that's changed and I'm sadly not sure if it's because I've grown used to it or that the amp is still burning in? I have less that 25 hours on the thing so far...so not a ton of time. Although I'm used to needing to burn-in tubes which is of course not a consideration here.
Anyway..on to my thoughts (standard disclaimer, I have relatively older ears (45+ yrs) that have been abused by loud cars - YMMV). If budget allows, the CTH and LCX can co-exist nicely in a collection. They are different enough experiences and cater to slightly different use cases. The CTH is a fun, easy to listen too amp. I find myself just enjoying the music on the CTH vs analyzing the music on the LCX. The CTH adds that tubey goodness that seems to just work with the Sennheiser HD line. The LCX resolves the music better, has less roll off on the highs, more extension on the lows which sometimes make it sound like a darker amp depending on the source material - bass goes deep. This can sometimes cause my 6xx's to bloom on the low end (especially with modern recordings with muddier tracks and darker voices like Ray LaMontagne's new album). It also causes the 6xx to lose a little resolution up high causing cymbals and the upper registers of guitar and voice to crash. But with older (read: less dynamic) recordings, the LCX brings out parts of the music I had never noticed before. So if your music collection is all over the map like mine and you have some older stuff that you want to experience differently (I'd say better), then get the LCX. Just don't expect a huge difference...it's all nuances. During my listening session, I went back n' forth between the two amps preferring some tracks on one vs the other...usually based on either the bass blooming or treble crashing some. I found the 6xx with sultry female voices to be a treat on the LCX (Melissa Etheridge Tracy Chapman, Tracey Thorn aka Everything but the Girl). Whereas Elle King and Florence + the Machine needed the smoothness of the CTH. Of interesting note, I'd list Hannah Reid from London Grammar as a sultry voice, but her range is off the hook and certain tracks could go either way on these two amps.
A word on the use of balanced cables... For the purposes of this listening session I based all of my thoughts on using the SE ouputs only. Once I switched to balanced on the LCX, things went (slightly) next level. The already resolving LCX became more so. There was more of everything, but in particular there was more air or expanse (The gated reverb on Melissa Etheridge's voice on the Brave and Crazy album was well...crazy good). Of course with more of everything, there was potential for good and bad. While mostly good, the balanced output also punctuated any flaws in the recordings or in the limitations of the headphones. I think this was why I initially preferred my other cans over the Sennheiser 6xx on the LCX. During that extended session I used the balanced input exclusively. But once I sorted source material, the music I like on the LCX was even better via the balanced output. Side note: I found on songs that could get overly bloomy in the lower registers on the HD6xx sounded nicer on the HD600 with the balance cable. The 600's are well known to be less dark than the 650. Interestingly the HD600's also reduced the crash in the upper register...weird.
Summary... If I had to boil this down to a couple sentences (and yes, I can be wordy)...I'd say this. The CTH/MD Sennheiser HD6xx is a tough combo to beat. Regardless of headphone choice, the CTH is smoother (but not necessarily warmer) easy to listen to and fun. The LCD is more resolving with a larger and more complex sound stage (but not necessarily brighter - in fact can be darker), but certainly more analytical and nuanced. They can easily co-exist, especially if you like to A-B amps, cans and songs. If budget allows, I'd recommend owning both. Even more so if you plan to own super dynamic cans like the Focal Clears, sensitive IEM's or magnetic planar headphones from Mr Speakers, HifiMan or Audeze. Also it's worth owning a set of balanced cables with the LCX.
Hope I'm not too late on this follow-up and hope this proves helpful.
Thanks for the thorough and excellent write up, answering my questions perfectly. My wallet and I are going to have to have a heart-to-heart to figure out if this one is gonna fly or not...
Reactions: themuna
post-14332042
Post #168 of 464
abvolt
California
California
You'll really enjoy this amps sq if you get one, I was very surprised on how well it sounds for an inexpressive amp I'll say it will be hard to beat for the price..enjoy
post-14332199
Post #169 of 464
PointyFox
I just ordered this to go with my Andromedas and Z1R..
post-14370011
Post #170 of 464
Pott
Question: my office setup is currently a Schiit Brifrost (DS) -> Schiit Magni 3 -> Audio Technica M50s.
I'm receiving some Meze 99 Neos tomorrow, and I'm considering an amp upgrade.
The CTH seems to perform better with high-impedence headphones which I've no interest in (got a Jotunheim -> HD650s at home).
I figured the LC may be a good alternative...
Thoughts?
post-14370019
Post #171 of 464
Dnguyen926
California
California
The LC is a fairly neutral amp maybe a slight warm tilt. I don't have any experience with the Magni 3 but when I had the Jot and the LC I actually prefered the LC more. The sound stage is wider, it is also less analytical and in your face than the Jot which makes for a very relaxing but enjoyable listening experience if you're working.
post-14370656
Post #172 of 464
avsmusic1
Connecticut
Connecticut
I'm in on the drop with the SDAC that went up today. I know some have said they aren't sold on the pairing with the he-560 but I've heard more positive than negative so I figure I'll give them a shot. Seems to be a decent secondary market for them too if it doesn't work out....
Any recs for a "value" balanced cable for the 560?
post-14380413
Post #174 of 464
jsmiller58
Isolated
Isolated
Question... I am wondering if the LCX is worth getting in my situation...
I currently have the following DACs and amps
Topping D50 DAC
NFB 11.38 (integrated DAC Amp)
iFi xDSD (integrated DAC Amp)
CTH Amp
Aune X7s Amp
MD O2 Amp
The cans I usually use are:
Focal Elex
Sundara
1990 DT Pro
TH-X00
HD660s
HD58X
Would the LCX offer a sufficiently different sound to make sense? How different would it be?
post-14380604
Post #175 of 464
snip3r77
I'm thinking of the Monoprice Cavalli( ETA August-ish not confirm ) vs this?
Should I or should I not?
post-14380613
Post #176 of 464
displayname
Dallas, TX
Dallas, TX
While the massdrop deal is on and everyone is asking the same type of questions, has anyone compared the LCX to older amps that go for about the same price on the bay and other places. I've been eyeing a Burson HA-160, but haven't heard of many people who have used both.
I get the impression that LCX might have the upper hand with overall design, but Burson has top end parts and is built like a tank.
post-14380640
Post #177 of 464
jsmiller58
Isolated
Isolated
I think that Monoprice has delayed their new offerings until October.
post-14380659
Post #178 of 464
jsmiller58
Isolated
Isolated
I am surprised as to how few reviews and comparisons there are for the LCX... In the balance that troubles me...
For me I already have a few amps and would like to know if this one adds something different to what I have. And I am thinking of others as well, Questyle 400i, Yulong Aquila, an R2R either from MD or Audio-gd... Too many choices and would love to get more insight into the LCX...
Reactions: displayname
post-14380684
Post #179 of 464
displayname
Dallas, TX
Dallas, TX
It's interesting to me because the reviews here seem overwhelmingly positive, but I've seen some grips about build quality on other sites. Including on MD reviews where someone points out a spark if the power supply is plugged in to the socket before it's plugged into the unit.
post-14382499
Post #180 of 464
abvolt
California
California
Well the only other amp I can compare the LCX is with my wa22 which is not a fair comparison one is all tube the other SS. But I will say that the LCX is an amp I don't get tired of listening to it's a great sounding amp and well worth it's price, I'm very happy no regrets..enjoy
