Massdrop x Focal Elex Review & Measurements
Dec 4, 2018 at 3:25 PM Post #1,081 of 2,030
FWIW I don’t find the Elex heavy at all. I do think the headband is problematic though - it’s not padded enough and causes a hotspot on top of my head after a while. Which is why I modded mine:
amazing looking strap. I just have some neck issues.
Dec 6, 2018 at 10:21 PM Post #1,082 of 2,030
ELEX & ECHO both are European handmade .
Anyone have this setup? GO or NO go?
Jan 6, 2019 at 4:14 PM Post #1,083 of 2,030
Hello all. I’m currently debating whether or not to get the Elex. I will be pairing it with a smsl m9 dac that uses dual akm4490s. Its a delta sigma dac and if their implementation is similar to the su-8 i already own it should be za fairly detailed dac with possibly a slight reduction in glare.
I want to ask what solid state amp would be recommended to get a warm signature from this headphone. I don’t really like a bright sound. My fav setups I currently have are some Audeze lcd2c with thx 789 and mimby with slight reduction in treble and midrange. Another one is schiit asgard 2 with smsl su-8 and hifiman he-400i with dekoni perforated lambskin pads. The final is topping D50 with thx 789 and sennheiser hd6xx.
What does everyone think. Is the Elex a worthwhile investment for me?
Jan 6, 2019 at 4:54 PM Post #1,086 of 2,030
It is warmer than it was with other amps I have tried with it but I wouldn’t classify it as warm. I would say it’s pretty neutral with great resolution and a fast, accurate bass. It has the ability to make the hair on my arms stand up with good mid range vocals or a good bassline. I have a SOTM SMS-200 streamer going to a V850 dac to a V250 amp. I am using the balanced output to and from the V250.
Jan 6, 2019 at 5:02 PM Post #1,087 of 2,030
Thanks for the detailed reply! I’ve been considering a vioelectric amp as well for some time so this might give me another push down that road. I was thinking of pairing one with a r2r dac like somefrom Metrum. Maybe the r2r would a bit more warmth?
Jan 6, 2019 at 5:24 PM Post #1,088 of 2,030
I had the good fortune to pick up the Elex along with the MD x Alex Cavalli Liquid Carbon X amp and love the warmth or as some say the "Cavalli Sound" I get from the Elex. I do have the 789 as well, bought primarily to use it with my planar's, and far prefer the LC with the Elex. The Elex has a much more analytical sound signature, think HD800 and is just nicer with the LC. The Elex is a good complement to the Planar sound.
Jan 6, 2019 at 5:56 PM Post #1,089 of 2,030
Here's some pad changing data using the Brainwavz Microsuede (oval) pads vs the stock Elex pads.
Basically, it changes the Elex from a neutral-leaning-bright headphone to a warmer/laid back headphone similar to an HD650-ish sound but with the characteristic Focal detail and dynamics and better sub-bass response.
Frequency Response (Raw, and compensated)
Waterfall CSD for Stock vs Microsuede
Here's how the Elex with the pads compares to the Sennheiser HD58X:
Measurements were performed on MiniDSP EARS. Compensation curve is using the supplied HEQ calibration file, which IIRC is based on Harman Target curves. I don't know exactly how accurate the CSD data is, so take it and everything here with a grain of salt.
Jan 6, 2019 at 7:12 PM Post #1,090 of 2,030
Jan 6, 2019 at 7:14 PM Post #1,091 of 2,030
Jan 13, 2019 at 3:54 AM Post #1,092 of 2,030
The 2-year warranty for the Elex is handled by Massdrop directly because it is a collaborative product with Focal. Thanks for all the graphs and pad information. The Elex suits my needs better than the DT1990.
Jan 13, 2019 at 11:10 PM Post #1,093 of 2,030
Can you elaborate why you prefer the Elex over the DT1990? I never got the DT1990, but was very interested for quite some time. I do really enjoy the Elex, but I will say, is at the extreme of what I can tolerate treble wise. One of the best qualities I like of the Elex is that it sounds great listening at low levels.
Jan 14, 2019 at 1:29 AM Post #1,094 of 2,030
Have you tried the Dekoni pads? I was also bothered by the Elex treble with stock pads, couldn’t listen to it for more than half an hour, but after I switched to the Dekoni Elite Velour pads, the bass is lifted and the treble is tamed down and I could listen to it for hours without fatigue. But I guess that basically turned Elex into Elear..
Anyway here’s the article on Dekoni pads.
https://dekoniaudio.com/so-you-want-some-focal-measurements-with-the-dekoni-audio-ear-pads/
I also have DT 1990 (w/ balanced pads) and I feel it’s more V-shaped than Elex w/ stock pads, with more elevated mid bass, more recessed mids, darker high mid/ lower treble and brighter treble; the Elex is more neutral and has better extensions.
Jan 14, 2019 at 1:30 AM Post #1,095 of 2,030
I currently own the DT1770 and I kind of regret it. That headphone sounds very dark with no fine detail to the sound and the treble then jumps up. The DT1990 was just a bit better but nothing stands out when I tried it at RMAF. Before I ordered the Elex. I tried the V3 of HE560 since I like the original version two years back. But the version I got was distorting in the mid-range and other QC issues. I return it. I enjoy my HE-400 far better and it has much more pronounce bass and clear in the details. I was concerned that I might hear the Elex metallic coloration but that was not the case. The Focal Elex is outstanding for vocals. Male vocals and chorus are the best and natural sounding I ever head on a headphone. Very smooth and very detailed. The Elex was being driven by Monoprice Liquid Platinum. I could not hear any harshness or edginess on the treble. A real keeper for me.
