Massdrop x Alex Cavalli Tube Hybrid Amp (CTH) - Dropping Monday
Nov 4, 2019 at 7:19 PM Post #1,186 of 1,397
BrokeSkoolBoi
VA/Miami
What dac should I get for my CTH?
Like how does this work... I connect my dac to my cTH Using rca cables. Then do I connect my source like my phone to my dac then my headphones to the amp. What do y'all re command I order to get the best quality. I'm lost and want to start using this amp
You're exactly right. Get a USB A to USB c or micro USB converter for your phone if you want to use that as a source. I'm using the topping d70 dac, you can just get an sdac if you only want a dac for the CTH. I liked the SMSL su-8 but it is more digital sounding than the sdac, it's more detailed as well however .
Edit: topping d10 should work well too
Nov 4, 2019 at 7:55 PM Post #1,187 of 1,397
buke9
Help and Recommendation Contributor
Kentucky
The mx3 didn't have a rca out that's why. Can you guys recommend some dacs that will work that I can also use my phone to play music through since my pc isn't functional until a couple weeks. Could I get like a ES 100, a fiio mk2 or q5. I can spend like $150
Well since this a going to be a desktop dac I would go with a desktop dac. A Modi 3 would be my choice as it is a competent dac and good support and has separate power and usb inputs so you can use any phone as a source that can go OTG which most will and even iPhones.
Nov 4, 2019 at 8:14 PM Post #1,188 of 1,397
BrokeSkoolBoi
VA/Miami
I keep forgetting the modi upgraded to 3. I vote for the modi 3 as well :ksc75smile:
Nov 4, 2019 at 9:02 PM Post #1,191 of 1,397
BrokeSkoolBoi
VA/Miami
What about topping d50 or the smsl m100 that seems to be really good for $80
D50 has a lot of popularity for its measurements , but I would take the Schiit warranty and it's good resale value over D50. Not sure about the m100.
I know it isn't in your budget, but I would steer away from getting the modi multibit. For the price there are better DAC's
Nov 4, 2019 at 9:51 PM Post #1,192 of 1,397
buke9
Kentucky
Probably not bad either just have no experience with it.
Nov 4, 2019 at 10:21 PM Post #1,194 of 1,397
buke9
Kentucky
Nov 5, 2019 at 1:23 AM Post #1,196 of 1,397
NiTROAUDiO
Member of the Trade: Second Hand Audiophile
AKA SecondHandAudio, BettyL, bettyjo, Rezerf
Athens, GA
I would only buy the SU-8 if you see yourself getting a balanced amp in the future, and even then, if you're going to get one you'll probably end up wanting a better dac eventually. No reason to spend more than $100 honestly. Whatever you like though!
That's why I liked the smsl m100 for $80. 32 bit 768K. DsD 512 bits, dual dac function. That's pretty good specs for $80
Nov 5, 2019 at 1:12 PM Post #1,197 of 1,397
NiTROAUDiO
Athens, GA
I'm just confused on how crap is supposed to hookup lol. Like. Could I use a es100 into my cTH. Or like a rca from my cTH into a fiio k3 line out then use a aux cord from my phone into the headphone in port of the fiio k3 then plug in my headphones into the CTH. How is it normally hooked up.
Nov 5, 2019 at 2:56 PM Post #1,199 of 1,397
BrokeSkoolBoi
VA/Miami
