Massdrop x Alex Cavalli Tube Hybrid Amp (CTH) - Dropping Monday
Dec 7, 2018 at 8:08 PM Post #1,007 of 1,397
buke9
Help and Recommendation Contributor
Kentucky
Honestly even after getting the LP, the CTH gets a lot of time with the 6XX. I still feel that synergy is one of the best sounding combinations I’ve ever heard. Also for $450? A no-brainer.
I think the CTH and 6xx’s is great also I think the Bottlehead Crack is a bit better with them but not by huge margins.
Jan 13, 2019 at 9:39 AM Post #1,008 of 1,397
Guidostrunk
Pittsburgh, Pa
Folks, I gotta tell you. Using an external power supply with this amp puts it in an entirely different level of SQ!
I purchased a used Acopian A28mt300 for $35 shipped. It looks like someone was bowling with it , but it works flawlessly, and I saved a good bit of money. Besides, you never see the power supply anyway.
This amp is a beast now. Way more transparent. The expansion in dimensionality, and space is off the charts. Bass extends way down, with insane impact and slam now. Mids and treble integrate with precision and fluidity presenting a much more realistic and lifelike presentation.
I totally went into it pessimistic. Thinking that it would be a miniscule change and then I'm stuck with this ugly power supply under my desk. Well, that's not the case! It sounds nothing like the amp with the walwart.
I'm totally blown away! @atomicbob has an entire writeup on the subject at a different place in which I'm not allowed to mention. Just google MCTH Acopian, and you'll find it.
Cheers folks!
Jan 13, 2019 at 2:23 PM Post #1,009 of 1,397
Sekka
Cheers folks!
Would you say it's a more noticeable change than rolling with 6C8G tubes?
Jan 13, 2019 at 4:41 PM Post #1,010 of 1,397
Guidostrunk
Pittsburgh, Pa
No tube has come close to making a change like this LPS. I'd put the MCTH/wLPS up against anything under 1k.
If you like that 6c8g. You should give the 12at7/ECC81 with adapter a try. I'm currently using a Telefunken 12at7 w/ adapter.
You get the same Soundstage as 6c8g, with more depth. And the magic of the best 2c51/396a. The 12at7/6201/ecc81 are way more transparent, with the best bass out of any tube I've ever rolled.
Jan 15, 2019 at 1:46 AM Post #1,012 of 1,397
BrokeSkoolBoi
VA/Miami
Jan 15, 2019 at 9:04 AM Post #1,013 of 1,397
jrhill
Melbourne, Australia
I've used a number of different power supplies with this amp and, as you'd expect, different tastes of sound support different quality of Linear Power Supplies, different valves, different headphones.
I'm using an AMB regulated supply with that 'tombstone' 6cg8 valve (or tube, if you want) and the total sound is quite dependent on the reg's output capacitor - I would expect this to be similar to other high quality supplies - there are some 'ready-built' supplies but they tend to be nearly as expensive as this whole amplifier - this one seems to be very good value for money and will benefit from adding a good quality cap on the power supplies' output terminals
Jan 22, 2019 at 7:12 AM Post #1,015 of 1,397
jrhill
Oh, forgot to add, I enlarged the hole to 38mm so the 6F8G/6C8G converter socket could directly plug into the pcb instead of using the extension socket ... I thought the 6c8g has a clearer heavier bass response than the Siemens PCC88 and a more detailed background too
IMO, it's still one of the best 'bang-for-the-buck' headamps available - this one has run nearly continuously (24/7) for the last 10 months without missing a beat and fills out the sound of the k701/2 extrememty well too.
Jan 29, 2019 at 1:54 AM Post #1,016 of 1,397
horaspaul
OK, so I and a bunch of newbies have bought into this Massdrop.
I love the reviews of this amp but am wondering whether there is a better power source than the included one?
Newbies need to learn the value of a "linear power supply" but have no clue what it is or where we can get one.
When my M/CTH arrives next week, we'll start using it with the included wall-wart.
Any other options for a LPS?
Jan 29, 2019 at 2:22 AM Post #1,017 of 1,397
jrhill
Not sure what a 'newbie' is really so a bit hard to suggest you build you're own using an assembled tested pcb as a base but involves working with mains power and this isn't something everyone's comfortable doing properly/safely.
Ready made - there's plenty of people that can provide good quality linear power supplies and it depends on the $s you have available and how far down the 'rabbit-hole' you want to go - plus, many people that are into this sort of upgrade have quite definite opinions about "good quality" or "good value for $s"
Some people aren't too keen on buying anything built in China but like most things, "it depends" - there are quite a few linear power supplies available from China that'll do the job very well indeed but you may need to ask for the slightly higher voltage this amp requires (28 volts at 360mA) - most of them only go up to 24volts dc
One of the 'good ones' is based around the ZeroZone Betta 11 pcb that is a version of the AMB Sigma 11 circuit that has been an excellent unit for this amplifier. There are a number of laboratory power supplies that'll also do a very good job and often cheaper too - I hope my rambling is of some help.
I'm not sure if the guys at Massdrop are designing a linear power supply - I'm pretty sure it'd be a big seller.
Feb 3, 2019 at 11:45 PM Post #1,018 of 1,397
horaspaul
Okay, I got my MCTH yesterday, burned it in overnight and did some listening this evening.
Hooked up to the Schiit Fulla 2 DAC, it turned itself off playing Earl Klugh, "A Time for Love," on Amazon music listening through Sennheiser 58x.
Hooked up to the headphone jack only on the same laptop, the MCTH again turned itself off playing Earl Klugh, "A Time for Love," on Amazon music listening through Sennheiser 58x.
It was the same source, a Dell Inspiron, same tune, and it triggered some "off" switch on the MCTH.
Any ideas why this is?
Paul
Feb 4, 2019 at 9:29 AM Post #1,019 of 1,397
joeike
Did the LED turn from white to red when it turns off?sounds like the protection circuit is being triggered maybe try different set of headphones just to eliminate them first.also check to see if the tube is in all the way sometimes it's kind of hard to tell they could be in partially and may need to be gently receipt it.
