Massdrop sennheiser hd6xx - love em what next
Jul 16, 2020 at 3:49 PM Post #18 of 31
Hi Daniel,
Your Yamaha AS701 probably already has a reasonable DAC in it, though a dedicated DAC like a BiFrost Multibit would surely improve your sound. I think you'd see a larger impact from replacing your Little Dot mk2 with something like a Liquid Platinum as I think that's the weakest part of your chain currently.
The reason I bring is up is that I've noticed the HD650/HD6xx to scale up with every improvement I've made to source equipment or Amp. Right now, running it out of a Gungnir Multibit -> Decware Taboo with great tubes, it sounds 85-90% as good as my Verite.
Of course, you'll also see improvements if you upgrade your headphones. Either way, best of luck :) This is the fun part of the journey.
Thanks,
Richard
Jul 17, 2020 at 11:14 AM Post #19 of 31
Hi Daniel,
Thanks,
Richard
yes i am looking forward to getting some new gear! i have been looking at the topping d50 and d70 dac as they look to be pretty good. probably leaning toward the d70 as the sabre can be slightly bright from my understanding. please correct me if i am wrong :) otherwise when it comes to tube amps im a little out of sorts as to what is considered good/great for the money. I have enjoyed the little dot mk2, but as you say it might be and probably is the weak link. Ideally i wouldn't want to spend much more than 300-400 on a tube amp. Maybe i should start a new thred on tube amps :)
thanks for the advice though!
Best
Daniel
Jul 17, 2020 at 11:29 AM Post #20 of 31
Balanced cables and the ifi hip dac... That combo is just over 200 usd. I run that setup from my laptop on the road. In the home office I run a balanced dac into a Schiit Jotunheim with great success.
Jul 19, 2020 at 11:43 AM Post #26 of 31
No problem Daniel! Mostly, there isn't a "right" way to do this hobby, and whatever you change, it likely won't be the last time you change your rig. I've had success upgrading amp and dac, but others really like upgrading headphones so do whatever you feel like. The only thing is to make one change at a time and let your ears tell you whether you like it or not :)
Jul 19, 2020 at 12:12 PM Post #27 of 31
Cheers, solid advice!
Many thanks
Daniel
Jul 19, 2020 at 5:20 PM Post #28 of 31
My advise would be to NOT sell your HD6XX in the mean time. Odds are you’ll return to them after all the upgraditis settles down.
Yes, that's what defines timeless products. And there's a lot of potential in these cans. Solid advice!
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ comms@ifi-audio.com
Jul 19, 2020 at 5:24 PM Post #29 of 31
Hello,
It took me a while to find the sennheiser h6xx (hd650) and i abcolutely love them. However i am now looking for the next advancement in this sound signature.
Any advice would be greatly welcomed as my quest for the next headphone pair begins.
HD700
HD820
HD800/S will likely be too lean for you
