Marantz HD-DAC1
Dec 12, 2016 at 10:15 AM Post #691 of 1,283
One word answer EQUAL ?!?
It has a dedicated headphone stage with the HDAM-SA2 module according to Marantz website. Wouldn't be surprised if they are exactly the same
A lot of these new compact lifestyle amplifiers also from the likes of Quad, Cyrus and Denon have dedicated and presumably good quality built in headphone amps. If you have speakers as well as headphones this means you don't necessarily have to have another box anymore. The features these amps have makes a lot of the headphone amps out there look very expensive. Of course a lot of people on headfi will remain dismissive of integrated amplifiers.
The CD player (see above) that has been added to the range also has the same module. Hence for someone (like me, mainly) who listens to headphones only via CD that's probably a nice one box solution as well
and how about sound quality? I saw that the dac chip is different from the dac 1 vs amp 1.
Have you or someone else made this comparison?
Thank you
Jan 13, 2017 at 6:57 PM Post #692 of 1,283
I have had the HD DAC 1 for a while. As much as I enjoy it (it is my only desktop unit) I am not into desktop that much and I only listen to headphone once a week. In large I am very satisfied with DAC1 but than I tried HQplayer and DSD128 upsampling. In short I cant get enough!
I highly encourage you guys to try DSD upsampling of HDplayer. I am still learning and the music file I listen to arent mine as I am using my friends laptop as I dont have a HQplayer yet, but I will buy it soon.
Feb 12, 2017 at 11:16 AM Post #693 of 1,283
I recently bought an HD-DAC1. As a headphone amp handling an analog signal from my CD player, it wasn't noticeably different in SQ from the Burson HA-160 amp that I already have. However, when used as a DAC in a 2-channel system with coax input from an Oppo 103, it offers better SQ than either the Oppo's DAC output or my AVR' DAC (Denon x4000). It's hardly a night and day difference, but what I note is greater depth and width to the soundstage and more precise imaging. I level-matched the inputs before making the comparison, for which I used FLAC and WAV files at CD-resolution.
Mar 4, 2017 at 4:50 AM Post #694 of 1,283
First: Question. Does the DAC click EVERY time it gets a new signal? Like its switching on or switching signals. It does not happen with a continuous sound in-put and its not that annoying, but if I click from one song to another the DAC makes a switch/click sound. Also windows sounds like hitting the back button on a file window.
I am assuming this is just the dac doing its job (and this is only in USB mode. I didn't notice in the optical input mode... but only checked that for a few minutes)
EDIT (I found the answer to the this. High end DACs add a relay switch instead of letting the DAC chip do the switching. It reduces strain on the dac chip and sound noise in the output signal while)
I know this is an old post I'm quoting but I'm thinking of getting HD-DAC1 and I'd like know does the clicking noise come from the device itself or is heard from speakers/headphones? I just got a Denon DA-300USB dac and it makes an extremely annoying popping sound from the speakers and headphones whenever it gets a signal or loses one, for example whenever I start or stop/pause a YouTube video. This is so frustrating that I'm considering replacing it with another DAC.
Mar 4, 2017 at 5:02 AM Post #695 of 1,283
I am also contemplating getting a DAC for my home setup with DSD capabilities and this seems interesting. Has this product been refreshed since its initial release? I had a marantz consolette (Airplay speakers) which i loved back then and they just went out of production. I have heard people talk about the clicking issue and would be interested to know more. Can anyone suggest any other DACs at this or a lower price point.
Thanks
Mar 4, 2017 at 10:23 AM Post #696 of 1,283
The relay click comes from the device itself and not through the headphones or speakers.
Thanks
Marantz released the HD-AMP1 a little while ago. It isn't quite a refresh, as it has a slightly different feature set and costs more, but it's an option if the DAC1 isn't quite what you want. As far as general DAC recommendations,
Mar 4, 2017 at 5:50 PM Post #697 of 1,283
I just bought one. The relay click comes from the device and is not audible on either its line-out analog outputs or its headphone output. It is not loud or disturbing at all (to me).
The Oppo Sonica DAC has the same retail price but no headphone output. I haven't heard it.
Isn't the HD-AMP1 essentially the same DAC and headphone amp as the HD-DAC1 with the addition of an amplifier for speakers?
Mar 4, 2017 at 9:44 PM Post #701 of 1,283
The clicking issues come when the sampling rate is switched.
If you use it with SPDIF (i.e. coaxial or optical) with your computer or CD player, you won't get that issue. It is only with USB input that you tend to get that switching sound.
Mar 5, 2017 at 2:30 AM Post #704 of 1,283
So there's no clicking when the audio signal simply starts or stops, like when starting or pausing a YouTube video?
Mar 5, 2017 at 6:28 AM Post #705 of 1,283
  I have ted via USB and don't have the switching sound. I wonder if the correct driver is being used?
Mine clicks when I go from a 44.1kHz track to a 96kHz track, or when I start another media (music to video) etc.
I wonder if it doesn't click if everything is played through windows audio and is output through at the same rate as per windows audio output?
I usually wear a closed headphone, so I haven't heard it in a while...
