kds5000
- Nov 6, 2008
Thanks for replying indydieselnut. It sure puts my mind at ease knowing now that mine isn't the only one with this hum
The vibration I feel is very slight when the amp's properly warmed up. There's no noise coming from the transformer so it's no issue. Will try some TAOC wooden footers soon too as it'll give the amp some ground clearance to aid cooling if nothing else...
And man, does this amp run hot!
Originally Posted by indydieselnut /img/forum/go_quote.gif When I first turn mine on (s/n 3), there is an audible hum. As the amp warms up (first 180 seconds) the hum subsides into near inaudibility. With no music playing, if I turn the volume up around 2-3 o'clock I can get a very subtle hum again. This is not "hiss" but a hum, just as you described it. I don't experience the vibration but I took the stock feet off and have the amp on a trio of Mapleshade Surefeet on a block of walnut supported by the Mapleshade rubber/cork footers. I had all that stuff sitting around so I thought I'd try it. Seems to be working well. Cheers! |
