Major problem with Clou Red
Jan 9, 2002 at 6:19 AM Thread Starter Post #1 of 18
Nezer
Antibacterial soap... kills bacteria... bad karma?
And it's a biggie...
My cat things it's tasty. This is *NOT* a good thing with a $100 cable!
Any ideas? If I had to choose between the Clou or the cat, the Clou would go!
Of *ALL* the things for her to chew on she has to choose the $100 cable!!
BTW, no real damage has been done yet.
Jan 9, 2002 at 6:40 AM Post #2 of 18
Tobasco comes in a nice matching red, leave that on for a few days and see if your cat still finds the cable a tasty toy. (Don't try this if you have a Chiuaua.)
Kelly
Jan 9, 2002 at 6:49 AM Post #3 of 18
Nezer said...
There goes my idea...
How about just leaving it & the headphones in a drawer or something when not in use?
Jan 9, 2002 at 3:45 PM Post #4 of 18
Kelly
The problem with this is she is a *very* strange cat. I'm afraid she might actually *like* it!! So, how are the dielectric properties of tobasco?
I'll test this out and give it a try.
Currently I am just putting the headphones away when not in use but I'm afraid that I'll forget one time and wake up to find my $100 cable in little pieces everywhere.
Jan 9, 2002 at 6:02 PM Post #5 of 18
Nezer, pet stores often carry a spray-on product that cats don't like -- it's designed to keep them from scratching furniture, but it's quite possible it will keep them from chewing cables, as well (actually, I think I'll try this myself, since I've already had to replace a set of Ety cables and a couple KSC-35s over the years
Jan 9, 2002 at 6:32 PM Post #6 of 18
I just worry she'll like the stuff.... She is a *very* strange cat.
My parents had a cat once that used to eat the plants (imagine that). So, they bought a pepper plant to teach it a lesson. That little SOB *loved* the peppers!!! Now, mind you, these were too hot for even me so that cat was either crazy or was just torturing us. I think both.
I'll try that spray-on stuff and hope it doesnt make the cable all sticky. If it does maybe I'll buy some techflex and coat the cable *under* the sleeving so I don't have to deal with a sticky cable.
At least the Koss are cheap enough that replacing them isn't really a big deal. If the cat would chew up the standard cable I would see that as an opprotunity to upgrade but I don't think there is an upgrade from the Clou Red.
Jan 9, 2002 at 7:00 PM Post #8 of 18
Yes do check, often the cat-avoid products are citrus oil based, which might effect the plastic coating of the cable. THiss approach might be better that tabasco thought, which can be a skin irritant.
Jan 9, 2002 at 7:23 PM Post #9 of 18
Originally posted by morphsci
Just be sure to check the label on the spray-on stuff. Sometimes it can dissolve or fade things. You don't want a Clou pink, do you?
I dunno, do the pink ones sound better?
Jan 9, 2002 at 7:42 PM Post #11 of 18
Originally posted by Lambda
what about getting rid of the cat?????????
I covered that topic already. The cat stays.
Jan 9, 2002 at 8:12 PM Post #13 of 18
Originally posted by KR...
how about locking the room the cables are in, so that the kitty can't get in there?
ROTFL, you don't own a cat do ya? She isn't gonna get locked out of *anywhere* in this place.
It's not a bad idea except it's the main living area where I listen and I cant get her out of here easily nor would I really want to, she's 99.99% good but that .001% can be really agravating.
Jan 9, 2002 at 9:22 PM Post #15 of 18
Originally posted by ponzio
I think you should use your old cables to hog tie the cat
Now thats creative... Fortunatly (for the cat) I bought the Clou with the HD600s used without the old cable...
