yangian
- Sep 22, 2014
How about Magni 3 compared with Massdrop CTH for HD600?
When it starts to be distributed the reviews have come up, so even that question will go unanswered.How about Magni 3 compared with Massdrop CTH for HD600?
It's because I intend to buy the RCA connector from Introprose, the one from the photo below:
Except that the feet of Magni 3 are different and the vendor of this connector is making available the feet of the previous versions so that the Magni is aligned with the Modi, but I do not know how to remove the feet of the Magni 3 and put the feet of the previous version.
Hi guys, I was thinking of getting the Magni 3 to replace my portable dac/amp setup. Unfortunately that would mean I’d need to use a 3.5mm to rca cable to connect the phone to the Magni.
I then looked at the modi2 as a dac, but it draws power from the phone. Not an ideal solution either.
3rd option is to look for a DAP with line out but that would likely cost more than the Magni+modi combined.
What do you guys suggest?
Thanks for the help but I decided to use a mini rack:You can probably remove the feet by pulling with needle nose pliers. The feet are likely held in by little push-in "mushrooms". Let us know what you see after you pull them out.
Older models had stick-on feet, and the heat those units generate sometimes melts the glue. But with that connector in place yours probably won't be moving around much, so the new feet will likely stay put.
I don't think its the increase in power that is the difference but the basic sound signatures of the amps designs. While I haven't heard your amp I've compared the O2 to the Magni3 and your description of the sound from your HE400i and O2 pairing is what I heard also, lacks bass, rather thin over all sound and sometimes harsh in the highs. The Magni3 to me is slightly on the warmer side and a decent/good pairing for the HE400i and other headphones that can be considered slightly bright.Did anyone of you upgrade to Magni2/3 from a more weaker amp like the O2? if so did you notice much of a difference?
I finished a building a 'Heed Canamp' clone, its an old headphone amp that was released around 2007, regarded as pretty good at the time but seems extremely overpriced at $400 now with things like magni 3...
I definitely prefer it compared to my O2 with he400i's, has that head bobbing sound now and I can truly enjoy them (overdriven guitars finally sound right), but I dont know if its the increased power that is making the difference or the amp istelf.
its only around double the power of O2 while the magni 3 is even more powerful than that, I'd say I spent more on the project than the Magni3!
It was a fun project but it just feels like waste of time if all I needed was more power which the magni 3 gives for less and without the effort.
thanks for the reply, I would have never have bought the O2 if I had known how different solid state amps could be, the general impression I was given is that all SS sounded the same with slight difference in how they sound when pushed to their limits. Really nice to know this amazing new sound is my from my homemade amp's unique circuitry and not just the extra wattsI don't think its the increase in power that is the difference but the basic sound signatures of the amps designs. While I haven't heard your amp I've compared the O2 to the Magni3 and your description of the sound from your HE400i and O2 pairing is what I heard also, lacks bass, rather thin over all sound and sometimes harsh in the highs. The Magni3 to me is slightly on the warmer side and a decent/good pairing for the HE400i and other headphones that can be considered slightly bright.
What is the recommended input voltage?
