SomeTechNoob
- Nov 7, 2016
Well how loud have you set your macbook's volume?
Guys, I just got my magni 3 and pairing it with my HD6xx I am very underwhelmed to the point I think there may be an issue with the amp. I am running it straight out of my macbook pro (no dac) with rca adaptor plugs. On high gain I have to crank it all the way to 3 o clock before i get decently loud sound.
Is it an issue with me not having a dac?
What is the volume set at on the Mac or the player?
My Magni 3 will make my ears bleed with HD6XX's.
Agree with the others here. Max out your source's volume, let the Magni handle volume control. My HD6xx's will get insanely loud with my M3...Guys, I just got my magni 3 and pairing it with my HD6xx I am very underwhelmed to the point I think there may be an issue with the amp. I am running it straight out of my macbook pro (no dac) with rca adaptor plugs. On high gain I have to crank it all the way to 3 o clock before i get decently loud sound.
Just grabbed mine (plugged into USB of PC into Modi 2 and thence to the Magni 3 - I can't crank it on low gain with the 6xxs. Something's up... I'd try another cable before freaking out, though. Monoprice are fine and inexpensive, pretty sure they carry that config...Completely understandable response. I have double and triple checked that my Mac's volume was at max. I also tried other sources such as my ipad (again, with max volume) and iphone and the issue still persists. This magni 3 is actually a second replacement as the first magni was also experiencing the exact same issue with the power. This leads me to believe that there is something wrong i'm doing on my end (becuase, you know, what are the odds that both amps would be faulty).
These are the RCA plugs I am using, btw:
https://www.amazon.com/gp/product/B019D048XC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Most likely yes. Is you laptops volume turned all the way up? If so then laptop output power is just to low.Guys, I just got my magni 3 and pairing it with my HD6xx I am very underwhelmed to the point I think there may be an issue with the amp. I am running it straight out of my macbook pro (no dac) with rca adaptor plugs. On high gain I have to crank it all the way to 3 o clock before i get decently loud sound.
Correct. And, you need to be aware that the volume control on the Magni 3 itself has had the logarithmic movement extended and smoothed to allow a finer gradation of volume than the previous models. I regularly run my 600ohm HD540 Ref1s at between 1pm and 3pm and the 300 ohm HD6xx, when I had them, wouldn't be far off that and with plenty of volume, depending on the recording level. That's using the Mimby.I had this problem and then realized the Magni 3 really needs a 2V signal coming in from the DAC otherwise it will sound anemic with the HD6XX. Not sure what voltage you get straight out of the MacBook Pro.... Try and make sure you have the max volume output from the laptop.
