- Mar 20, 2010
Not really. I'm constantly adjusting volume, so it wouldn't bother me.
Found the culprit. Inside my dolby access app, the profile is set to “Movie” instead of “Gaming”, and for whatever reason, the volume in “Movie” profile is significantly higher than “Gaming” one. Switching back to Gaming fixes it.Not really. I'm constantly adjusting volume, so it wouldn't bother me.
If you're not using optical, you might as well save money and just get the G5... optical is required to send Dolby to the G6.Because I want console capability too (has to be USB, ps4 slim) I will be getting the Creative G6 and wanted to get the AKG K612. Can the G6 easily drive the 612 or would the 702 be better ?
Man, if I had the GX, first thing I'd buy myself would be the suede pads from Dekoni. Just as isolating as the leather/pleather, but with the fabric comfort I'd want. I wish Audeze would've let me keep them long enough to test those pads out too. Though of course, I'd have to ask Dekoni too. LOL.Received my LCD-GX today, have about 2 hours listening time with music on them now. No movies or games yet.
Man, this thing can easily double as a “high-end” headphone, I really like the sound signature with music, not as dark as the LCD-3 and LCD-XC I knew.
I think I will replace those pleather pads with real leather ones though and get me a longer cotton sleeved cabled, not so fond of that plastic braided one and it’s too short anyway.
But those are little annoyances that can be solved, the sound is what is important and I really like it.
Also, out of all the headphones I'd want... the Audeze GX + Dekoni suede pads is actually my number 1 want atm.
I haven't heard the LCD-X. But one thing keeps me from being like "yeah, i'd definitely go for it". It's the weight. The LCD-X is one big bertha. I think the GX is as low as about as much as I'd want in terms of weight, today.LCD-X vs. LCD-1? Really interested in your opinions as you seem to like it better than the Panda.
The LCD-1 is suuuuuuper light. Like really, it's quite noticeable. That really helps long term comfort.
As for LCD-1 vs GX... ehh... it's very different. I think the LCD-1 falls outside what I'd associate with the LCD sound, and feels like a reference headphone in terms of how it produces sound. The LCD-GX as well as the LCD-2 and Mobius, share a trait that feel very Audeze, and is special in its own way. Not necessarily better, just different. So I can definitely say that if you want to experience AUDEZE, I'd get the Mobius or GX. But in terms of accuracy, I think the LCD-1 wins. It just sounds like its suuuuuper accurate, while the others are more fun, and different, and unique.
As for Panda vs LCD-1, the LCD-1 sounds clearer, is open backed so the soundstaging is better, and sounds higher fidelity to my ears. It may come down to the fact it's open vs closed, and the Panda having a bit of bass bloom which the LCD-1 does not suffer from. Really, they're both excellent, but different enough where its not a fair comparison.
Certainly. I should point out that I'm not really someone in need of a closed headphone. If I was... I would absolutely steer towards something like the Panda. It's fantastic. Kills at least two birds with one stone. Wired and bluetooth. Though it needs to be said the Mobius is also fantastic. Just... I'd say the Panda edges it out for me due to it being passive in wired mode, while the Mobius always needs to be on, even while wired. That makes the Panda just a bit more usable for me specifically, though it lacks a lot of the other features that the Mobius has like headtracking, vss, eq presets, etc. The Mobius is more fully featured, for sure, and if you weren't worried about wired connectioin to use with your own gear, the Mobius is hard to pass up.Sorry, I meant GX of course, I just edited my typo.
Thanks for your impressions. You nearly made me cancel the Panda with your previous post but you just reminded me that it's closed.
And bluetooth is handy as well although I don't mind a cable. But I needed a closed one in that category.
Other than the Dolby decoding over optical, both Creative models are identical, and will drive a K612 just fine.
FYI, PS4 only sends surround signals over Optical or HDMI. If a game has it's own binaural headphone processing mode built-in (like Naughty Dog games, some DICE games, Overwatch), then the "surround" processing is already done and you'd be able to hear it over USB. I'm hoping the next generation of consoles and accessory devices remedy this, but until then I would rather have an original PS4 or PS4 pro instead of the PS4 Slim specifically because of the optical port. I'm not trying to be a downer... just don't want you to be surprised.
Now you've got me questioning myself... the Soundblaster E5, G5, and G6 all share the same enclosure, and the E5 and G5 had the same DAC and amp inside (but the E5 had a battery, bluetooth, and a second headphone output instead of the mic input on the "front"), but it's possible the G6 has a different DAC and amp. The G6 is one I've never tried in person, but those on this thread have made several positive posts about it. If it is better or not, I will say that even the G5 was good enough for the AKG K612 and K712, and I was quite pleased with the G5 + Sennheiser PC37X for a pretty "smooth" signal chain for streaming. The G6 could only be the same or better.Thanks for the comment.
I honestly do not really care much for surround sound, aslong I can drive the headphones + a mic and have good audio quality like that. I have the HyperX cloud II at the moment and only use them in stereo anyway.
Gotta ask tho: Doesn't the G6 have a much much better DAC and AMP? Wouldn't that be a better fit for very fierce headphones like the AKG-line up?
