Macbook Pro 2016 with Touchbar Sound Quality Discussion
Discussion in 'Computer Audio' started by emerald core, Mar 7, 2017.
  1. Emerald Core
    There are few threads discussing new smartphones sound quality in the portable gear section. I thought, it is legit for a Macbook to get a thread discussing the same.
    What do you guys think for the new soundcard ? how does it compare to other portable sources (iPhone w/ adapter or iPad Pro)?
  2. clinkzclinkz
    The sound from 2016 macbook pro with touch bar is amazingly good but it seems 48khz/24 bits at most. However, it sounds surprisingly good and way better than 2013 macbook pro. What is the chip it used inside of it
  3. Gavin C4
    I almost never use the 3.5mm jack on the macbook pro touch bar. I usually connect it to the dac through the usb C port. But as far as daily youtube and media consumption, it is just fine.
  4. ThunderBolt03
    Does it still have toslink output on the jack ?
  5. winders
    No....
