memphiskat
- Dec 9, 2008
Hello
I've started using my M-Audio FastTrack Pro with my MacBook as an outboard DAC/headphone amp. How I should set the preferences in AudioMidi setup?
If I choose "Properties For"..... Fasttrack Pro - I can set the input and output sampling rates and bit depth.
Is the USB connection considered an input? Or is this just for the FTpro's analog & spdif ins/out? Should I set the in/out to match the source, I have sources/files that are 44/16, 48/16, 96/24.
I have a file that's 96khz/24bit. Do I need to set the "Properties for FTpro" and "audio output" for 24/96?
I asked tech support at iBasso if their D2 could handle 24/96 and they answered that the limit of USB is 16/48. Is that correct?
Also when using iTunes should I set the audio out to match the source? There seems to be some confusion on this.
I know it's a lot of questions, but any help would be appritiated.
Karl
Karl
