m50x and iPod. Help!
Jun 27, 2016 at 4:21 PM Thread Starter Post #1 of 10
TheJam
I've ordered new headphones, the ATH 50x. I will be listening on my iPod Touch 6th gen. I'm wondering what I need to do to get the full experience possible with these pair of headphones. Will a DAC make any difference? Also, will an AMP be required for these? I purchased the bundle with an amp, but I'm just curious to how much it is going to benefit. Any comments will be appreciated. Thanks!!
Jun 27, 2016 at 8:13 PM Post #2 of 10
My understanding is that the iTouch 6 would have very good audio if it is the same audio in the 6 series phones. In which case, a DAC won't help. Now if you find you are listening at or near the maximum volume with your headphones, then an amp could help.
What amp did you get?
Jun 28, 2016 at 1:50 AM Post #3 of 10
I think most likely, you should be doing just fine.  The M50X doesn't require much to back its sound, and I don't think a DAC or an amp would significantly change things.  I think perhaps the money is better saved for future purchases, but that's just my 2c.
Jun 28, 2016 at 8:32 PM Post #7 of 10
Most of us assume that if you are hanging out on Head-Fi, you will get upgraditis and get further into the hobby
The only problem with that is I'm not rich.
