M3 power supply, which transformer do I need for my Tread?
Aug 26, 2005 at 10:25 AM Post #3 of 4
25 0 25?
get the m4912. with the leads, connect the black to the white then connect the red and orange to the tread. thatll give you 24v before rectification and ~33 after allowing you to run a nice high voltage from the tread to m3. im running mine (i used an m4624 though, neater solution) at about 30v.
Aug 26, 2005 at 10:35 AM Post #4 of 4
Originally Posted by skyskraper
25 0 25?
12-0-12...
edit: nevermind- I see you were commenting on the first link. That one would also work if the secondaries were wired in parallel.
