M2Tech USB to S/PDIF Output Interface (RCA Coaxial)
Status
Not open for further replies.
Type
For Sale
Currency
USD
Price
99.00
Oct 15, 2011 at 9:54 AM Thread Starter Post #1 of 1
DjAmTraX
Now known as: HiFiGuy528
Unit is in like new condition.  I have a new DAC that has a good USB input (Musical Fidelity V-DAC MK-II) so I no longer need this.  Works with Mac & PC.  No external power supply required
Sells for $200 on the web.
**** $99 delivered to your door (lower 48 States) ****** Pay Pal ok.
The hiFace from M2Tech is a compact USB to S/PDIF converter that allows for delivering superior sound streaming from a computer via the USB port. The output can be plugged into any digital to analog converter that accepts S/PDIF signals.
Digital audio up to 24-bit/192kHz resolution is enhanced by two stable oscillators combined with custom stable drivers for both Mac and Windows systems. The unit features an RCA coaxial output and is powered from the USB bus.
Compact USB to S/PDIF converter
Two highly stable quartz precision oscillators feature very low jitter and phase noise
Features excellent hort and long range clock stability compared to oscillators normally found on commercial CD players, and reinforced by a board supply voltage regulator
A more stable clock is recovered by the DAC S/PDIF receiver leading to very limited image distortion and degradation
hiFace proprietary drivers allow for maintaining the original file quality without any loss of resolution
Sampling frequency rate constraints are also overcome, allowing for streaming 24-bit/192kHz S/PDIF music files to a DAC with certain player application
Drivers available for Windows XP, Vista and Windows 7, as well as Mac drivers for 10.4, 10.5 and 10.6
RCA coaxial S/PDIF output
Status
