dizza
- Jul 26, 2005
When using a headphone amp (Gilmore Lite) in conjunction with this sound card, do you use the 'green' line out or the headphone out? I found that using the regular line out causes a sort of buzzing noise when I turn the gain all the way up on my amplifier. The buzzing disappears when I use the headphone out, so I'm using that at the moment.
Also, has anyone noticed that when you are connected to the regular line out, the microphone gets unmuted everytime you reboot. I found that unchecking and rechecking the mute button solves this, but it is rather annoying. Any solution to this?
