Lol, no, that wont happen. The cotton grasps tightly on the walls of the filter, don't worry, there is no way that would going to fall into the shell with the drivers.Thanks for the advice. However, I'm afraid the cotton will fall of into the shell and there is no way I can take it out. Did that happen to your set?
LZ A6/A6 mini discussion and review thread
- Thread starter thejoker13
- Tags
- chifi iem tri-hybrid
I have been using it like this for 3 months alredy, and the results are atonishing for me. You can crank up a little bit more the volume and the highs are not going to pierce your ear.
JayGold
anyone tried the LZ a5 and a6 filters on the a6 mini? is it worth getting either of the packs? do any of them do something nice?
1clearhead
- Apr 5, 2013
You can checkout my A6mini impression with the 9 filter selection kit from the original flagship A6 posted earlier on this thread.anyone tried the LZ a5 and a6 filters on the a6 mini? is it worth getting either of the packs? do any of them do something nice?
Link: https://www.head-fi.org/threads/lz-a6-a6-mini-discussion-and-review-thread.919056/post-15355579
Enjoy!
-Clear
JayGold
Awesome..would you say the a6 black is more balanced/neutral than the a6m black?You can checkout my A6mini impression with the 9 filter selection kit from the original flagship A6 posted earlier on this thread.
Enjoy!
-Clear
1clearhead
- Apr 5, 2013
Actually, when using the black tuning filters of the A6 on the A6mini's the soundstage does tend to sound smaller, but still balanced/neutral. If I were you, stick to the original black tuning filters for the A6mini, since the soundstage does sound wider. Though, mysteriously the A6 with its own original black tuning filters installed does sound overall bigger and wider on all ends when compared to the A6mini. I'm sure the extra BA armatures installed in the A6 flagship model is making the biggest difference here.Awesome..would you say the a6 black is more balanced/neutral than the a6m black?
JayGold
Ah..how about the a5 filters?Actually, when using the black tuning filters of the A6 on the A6mini's the soundstage does tend to sound smaller, but still balanced/neutral. If I were you, stick to the original black tuning filters for the A6mini, since the soundstage does sound wider. Though, mysteriously the A6 with its own original black tuning filters installed does sound overall bigger and wider on all ends when compared to the A6mini. I'm sure the extra BA armatures installed in the A6 flagship model is making the biggest difference here.
1clearhead
- Apr 5, 2013
Unfortunately, I don't have the A5.Ah..how about the a5 filters?
JayGold
No problem! I do wonder if theres filters from other brands that fit now. Anyone with a larger budget willing to try?Unfortunately, I don't have the A5.
Have anyone tried A6 with Radsone ES100? Consdering buying them but have bad experience with A6 mini. While performed great with my M11 Pro, with ES100 was a crap. Not enough power?
It definitely has enough power. My guess is that you either got a bad unit from one of them or don't like one of them. I've got no problem with the ES100 and A6 but then again I enjoy the A6mini/ES100 combo as well......
Thx for fast reply. I have no problem with other iems, so that's probably A6 mini case.. Anyway I'll go with A6. We'll se
My bad. Just increased current for balanced output and it works fine. Forgot about this option, never had this problem before
prionsarebad
Apologies if this has already been answered.
Since getting the bqeyz spring 1 I realized I really like the piezoelectric highs and soundstage width.
How does the A6 mini compare to the spring 1 and is there any point owning both?
Thanks!
Thanks!
RikudouGoku
Member of the Trade: RikuBuds
Maybe better to get the A6 instead of the mini, when you already have the spring 1. I at least cant use my mini anymore since getting the A6, they are soooooo gooooooood.Apologies if this has already been answered.
Thanks!
