instantwin
- Aug 28, 2013
Anyone have issues with the tips slipping off the nozzle? the tips I got seem a bit small and cant completely cover the nozzle
Having the issue of the left monitor going out like others in the thread. Is there a suggested method to fix this? I've only used these about 4 times total and they are already having this issue.
How long are you able to listen, before the sound level drops?
Are you in a warm and humid environment?
It seems as though it's the heat / humidity that causes the dynamic driver to become quiet.
When it happens to my LZ A4, I just take them out, and let them sit for a while (few hours, or overnight) - and then they work OK again.
Well, I’m in one of the warmest, most humid states in the US where it’s almost always hot and generally about 70-80%+ humidity.
One thing that was different about the day is that I did have to go out for a bit and I kept them in. Perhaps that is the issue. It is not fixable besides letting them “rest”?
Are you still getting partial sound from the faulty side? Have you tried a different cable?Mine are now permanently messed up. I let it rest for a few days and went back to them.. no dice. Maybe I have to wait until winter time?
Okay, sadly then, it seems like you're A4 is officially dead. I assume your return period is well expired and did you try a different filter?I can swap the left and the right channels of the cable itself and the partial sound persists on the same iem, so it's not the cable.
The only other thing I might suggest is to put the affected IEM in a small plastic container or bag with some rice overnight to eliminate the possibility of moisture inside the unit.
