yosi231
- Jan 10, 2015
Yes, it's a worthy investment. A 100$ Fiio Amp/DAC is more than enough!
Thanks! Is fiio the best dac for sub 100$?
I will be listening to the a4's with my lg g4, will getting a 100$ portable dac/amp (cant waste more than this on dac/amp) a significant improvement that is worth it?
Maybe aomething like xduoo or fioo or whatever 100$ budget amp.
For $100 there are plenty of good DACs about at the moment. More convenient than stacking.
Is there any thread for sub 100 daps or should i just google search
"best portable dap for under 100$"?
There's no thread for sub 100 DAPs as far as I know. What kind of features do you want? There's Bluetooth, battery life, maximum supported bitrates, color screens etc.
Best sq, and battery is very important.
Maximum bit rate i dont really understand the difference im anewbie.
Screen doesn't matter much.
Take a look at the Rocker if you are in the US. It doesn't have all the features as some others like the Hidizs but it has a [COLOR=111111]CIRRUS LOGIC CS42L51 STEREO DAC and should have far better battery life. Also it's cheaper at around $60.[/COLOR]
[COLOR=111111]https://www.amazon.com/Bluetooth-Resolution-Lossless-Audiophile-Supports/dp/B01MZ50M0Y[/COLOR]
[COLOR=111111]I'm sure others will have some suggestions too. The Shanling M1 comes to mind and can be bought for about $100 but I think the battery life is only about 10 hours.[/COLOR]
I dont live in the us im from israel.
So do u suggest the M1?
10hrs of battery is pretty fine
BTW i cant find the m1 fir less than 160$
Don't forget Audioquest Dragonfly black or red. USB only no battery.
Nah i need portable daps..
When im home i use only speakers
I think one member already said the M1 synergy is very good with A4.
Its abit too pricey for me though, more than 100$ for a dap is too much for me.
