Motocrossman24
Standard pwm is fine with me, no need for dsd or mqa junk
Does anyone have a weird resonance come through your headphones from moving your mouse, or tapping the chassis? Just emailed Schiit about it.
Schiit dacs do not decode mqa, so it will be done via your pc before it gets to the dac, I personally find regular tidal hifi to sound best.
Mine is definitely a T plate, and I think it sounds great also. Might be the plate structure that is making the difference like you say. Powerful bass and yes, a large stage. I thought it sounded just a bit too forward compared to my current favorite, Sylvania, which I thought separates instruments in the depth perspective a bit better and is a smidge more delicate in the treble.
Prolly tube microphonics...typical of most tube amps...
While yes the mojo has an amp, I wouldn’t call it an amp, it’s just a quality dac that has a large following, we only used the dac portion of the mojo in comparison, running it through the lyr3 and preferred the lyr3’s multibit dac...it’s comparing a 200$ multibit dac to a nearly 600$ delta sigma dac
I agree...likely a microphonic tube. Typical of a tube amp? Yup, if you use microphonic tubes in them.
It's not an amp, and it's not just a quality dac, it's a portable DAC/amp. It's very capable to drive the my 80 Ohm Elear. Also it's not an off the shelf delta-sigma, its a custom FPGA... I guess the only way to tell how much difference the Lyr 3 would make, is to listen to it. I'm hesitant to rder one, because I'm very happy with the Mojo.
Has anyone used the Lyr 3 with IEMs? Curious to know whether there is hiss/noise.
OK, I wasn't focusing on MQA, just on moving towards lossless or hi-res audio. MQA is just the means to stream that.
