Luxury & Precision (LP) Portable USB DAC/AMP W1 and W2 (1123 New FW Available, Update Info on Post #1)
Oct 21, 2021 at 10:21 PM Post #4,141 of 4,307
Ufanco
Mind sharing where you got the cable from? So far the only low price pure silver cable I found is the Fiios cable but it doesn't come in 2pins flavor.
XINHS is the oem of some of these listed cable. Check this thread tons of great info on inexpensive cables. Might want start at the end it has a ton of responses.
https://www.head-fi.org/threads/low-end-cheap-generic-otherwise-bang-for-buck-cable-thread.891911/
Another excellent tool is @RikudouGoku database of cables quality along with links to them.
https://docs.google.com/spreadsheet...zTm4ei7HEfP8AI1zxswrMw2ho/edit#gid=1801072063
Link to XINHS store.
https://xinhs.aliexpress.com/store/910746107?spm=a2g0o.detail.1000007.1.56713912NUyk9D
Oct 22, 2021 at 8:34 AM Post #4,142 of 4,307
alavenue
Houston, TX
Anyone have issues with W2 not getting power from Samsung devices?
Oct 22, 2021 at 2:14 PM Post #4,147 of 4,307
stersa
Spain
this little beast moves my HD800S 75th very decently…:gs1000smile:
W2+S21 Ultra
best
Sisco
Oct 22, 2021 at 4:43 PM Post #4,151 of 4,307
abitdeef
Formerly known as ihatepopupads
I know there's some info in the previous posts but what usb c cables are you guys using? I'd like something like the stock cable size wise but more flexible and nicer.
Thnx. There was a particular brand a lot of people liked, maybe dd?
Oct 23, 2021 at 2:07 PM Post #4,155 of 4,307
Ufanco
I tried a ton of different c to c cables with the W2 and of them my best is the custom made ones by XINHS. The DDhifi isn’t bad but I had bad luck with them failing. First one came broken second lasted about 3 weeks. Third is sitting brand new in box.
The woo audio wasn’t too bad. The L shaped on is supper solid but shape isn’t for everyone. The two from XINHS I like the 40cm was $35 and the 17cm was $25. Might be cheaper or more depending on the cable used to make it. I used the cable linked below.
https://www.aliexpress.com/item/1005002994387021.html?spm=a2g0s.9042311.0.0.4e644c4dIOZmTQ
