LTC1144 Simple Conversion of 15V to -15V Supply
post-172863
Thread Starter
Post #1 of 7
braillediver
Cleaning up here at work I found some LTC1144 “Switched-Capacitor Wide Input Range Voltage Converter with Shutdown”. The Data sheet claims “Simple Conversion of 15V to -15V Supply”.
http://www.linear.com/prod/datasheet.html?datasheet=246
Has anyone ever used these? Seems like an easy way to get + and – from a single source?
I’m gonna play with these this weekend.
post-172982
Post #2 of 7
aeberbach
Melbourne, Australia
I've used a Cosel ZW30515 - similar thing except that this one needs no external caps. 5V in, +- 15V out. Headroom use the same component in a couple of their designs. Keep it as far away from other components as physically possible and make sure everything is grounded/shielded as appropriate, they use an osciallator internally. The ZW30515 comes in a can so it shields itself somewhat.
post-173071
Post #3 of 7
jasong
Seems like a bit of a communication problem here...the datasheet for LTC1144 says that it takes 15v (for instance) and converts to
-15 v, not 15 to +-15.
> It performs supply voltage conversion from positive to negative from an input range of 2V to 18V, resulting in complementary output voltages of -2V to -18V<
-jasong
post-173111
Post #4 of 7
CaptBubba
Not dumb enough fora custom title...so he thought.
yeah, and look at that graph at the bottom. The output voltage will be all over the place when using an amplifier, because the current drawn isn't constant. I don't see that as being a good thing. Or maybe I am wrong and just seeing problems where none exist.
post-173112
Post #5 of 7
braillediver
Thanks this input will save me some time.
I also found some OP27's. The data sheet has a phono pre-amp schematic. The best part is the References at the end
http://www.analog.com/productSelection/pdf/OP27_a.pdf
Jung, Lip****z I haven't read the books but the names are familiar.
post-173528
Post #6 of 7
tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
That's what the power capacitors are for -- to smooth out the current demand on the power supply.
post-173553
Post #7 of 7
Joobu
Capacitors can smooth out transients but in terms of switchers, inductor-less (capacitor) voltage converters typically have poor load regulation. Load variations over several mA can seriously affect the voltage. The way I see it, all switchers are a headache unless absolutely necessary (weight, size).
