PodPerfect
Greetings! Longtime lurker on the forums - and longtime fan/hacker of classic clickwheel iPods. I'm big about diyMods, experimenting with capacitors, flash upgrades, everything.
I've been experimenting with stereo Bluetooth adapters. As in, small form factor devices that accept a 2.5mm input, and that transmit to your Bluetooth headphones, speaker, etc. Every product I've tried (or asked about) has an annoying limitation: if the source volume I'm sending is low, but present, the transmitter will simply mute that part. Most of the time this is no big deal; most music has enough dynamic range that I don't notice.
But, this behavior can *ruin* certain tracks with long, quiet passages.
Example: Grantchester Meadows by Pink Floyd. It stars with quiet birds chirping. The device I currently use chops that section up.
Even worse, "Trio" by King Crimson. First 30-45 seconds, erased.
My questions are
My questions are
- Are there any robust Bluetooth transmitters out there that completely preserve the source? Can anyone recommend a product?
- Or is this some intrinsic limitation with the technology?
