balou
- Apr 7, 2007
Hi,
I always thought that just shutting off the LED completely at a certain voltage is a suboptimal solution, you may not know if the amp is still running by having a quick glance at it, leading to possible deep discharge of the rechargables.
So, I came up with this circuit:
The green LED should light up if the voltage is above the reverse voltage of the zener, and the voltage of the zener in turn steps on the garden hose inside the JFET (hey, I'm new at transistor circuits
), letting no current through.
So my questions are: will this circuit work? And at the moment, the current through the LED is just regulated by a resistor, not by a CRD. If I'd substitute the resistors with CRDs, I'd end up with 3 JFETs for the LED. Is this whole thing also possible with just two or one JFET?
there are also duo leds with just two connections, they change color according to polarity. would there be an easy low battery circuit for them?
