Low-level noise from my META42
Jun 3, 2003 at 4:18 AM Thread Starter Post #1 of 10
Trounce
I have a 24v regulated EPSAC (or whatever) PS for my META, and there is a constant amount of low-level noise even at the lowest volume with no ICs connected. Is this normal for a power supply, and if so, is there anything short of a line conditioner to fix it? Thanks.
Jun 3, 2003 at 4:30 AM Post #2 of 10
What kind of noise are you talking about? Is it a hiss or a hum?
Jun 3, 2003 at 11:13 AM Post #3 of 10
It's a hiss and its always there regardless of connection.
Jun 3, 2003 at 11:23 AM Post #4 of 10
walk around the house and turn everything on and off until the hum goes away maybe? who knows, might work...
Jun 3, 2003 at 12:25 PM Post #5 of 10
With what headphones? You can get that sometimes with very low-impedance headphones.
Jun 3, 2003 at 1:40 PM Post #6 of 10
Check and see if there is an output resistor installed in R8 or R9, if not you can put a 47 to 100 ohm resistor in one of the positions (not both) that should help eliminate hiss with low Z headphones.
Jun 3, 2003 at 1:54 PM Post #7 of 10
Hm, I just found that my META42 likes to buzz when in close proximity to flourescent lamps and computer monitors..
I think I need better shielding.
Jun 3, 2003 at 5:22 PM Post #9 of 10
It's not a buzz and it's not a hum.
It's noise, line-level static.
And I only hear it when I have my 75-ohm Ultrasone HFI-650s hooked up to it. With my DT770s, the noise is non-existant.
Jun 3, 2003 at 5:56 PM Post #10 of 10
Well then do what JMT suggested. Pop open the hood and see if there's a resistor in the R8 or R9 slot. Chances are there won't be one. If that's the case, you'd have to remove the jumper in either the R8 or R9 slot and replace it with a 47-100 ohm resistor (I'd stick with 47).
