Low end. Cheap. Generic. Otherwise bang for buck cable thread!
post-14957758
Post #1,456 of 4,642
hakuzen
That is a good point.
I have seen IEMs where the manufacturer specifically states that they include a cable of a certain impedance as part of the tuning.
I can’t remember an example off the top of my head though.
usual norm is the lower output impedance, the better.
it is exceptional when a manufacturer recommend certain higher impedance, in order to reduce hissing, or in order to alter highs frequencies. for the first case, special impedance adapters which don't increase total output impedance are recommended. for the second case, i'd prefer a better original tuning rather than modifying it with output impedance.
we know some cases: er3xr with impedance adapter, reduces noise/hiss and increase highs level, so it looks like near er4xr tuning (see clavinetjunkie video). the effect on kz zs6/zs5v2 is the opposite, higher output impedance tame highs levels. it depends of the impedance of the iem (balanced armatures impedance and crossover). in general, it's a bad idea to do this. if you want to alter frequency response of an iem, you'll get quite better control of the result by equalizing.
blessing is not an special case like these. i'm using xduoo x20 to test. its output impedance is 0.12Ω(single end) / 1Ω (balanced). in single end, i shouldn't notice tonal difference in blessing between 0.12+0.06(cable 125)=0.18Ω and 0.12+0.20(cable 165)=0.32Ω. it stays very low. in balanced mode, 1.06Ω vs 1.20Ω, not much difference either. so i'm going to sacrifice a bit of output impedance in order to get the darker background and better definition from the 7n up-occ wire.
of course, i'd prefer lower cable resistance, that's why i asked for 8 cores version of these cables (near half resistance).
post-14957813
Post #1,457 of 4,642
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Estonia
Estonia
Reactions: hakuzen
post-14958238
Post #1,459 of 4,642
Eddie C
Calgary, AB Canada
Calgary, AB Canada
Reactions: keoki
post-14958295
Post #1,460 of 4,642
hakuzen
Reactions: keoki
post-14958331
Post #1,461 of 4,642
SilverEars
What is the most conductive, least resistant cheap cable? Prefer if I can order it on Amazon if possible.
Also, @hakuzen . Have you tried measure two or more of the same cables, and did you notice any inconsistencies in the measured values?
Reactions: KarmaPhala
post-14958334
Post #1,462 of 4,642
keoki
in da middle of da C
post-14958345
Post #1,463 of 4,642
hakuzen
have you checked my list? it's ordered by resistance, ascending. when you see "/" between numbers, it means more than 1 cable measured. when many (more than 5 cables) measured, i show average resistance.
Will these work with KZ IEMs since they are .75mm?
i use them with kzs, even with flc8s (0.70-0.72mm). penon version pins are a bit thinner, go for these
post-14958355
Post #1,464 of 4,642
Slater
Cincinnati, Ohio USA
Hi friend, your transparent plastic Penon ones cracked, right?
I wonder if the black plastic version will crack also. I’d rather have the Penon ones because they are smaller and more compact than the Lunashops ones.
But I don’t want them if they crack and fall apart.
post-14958358
Post #1,465 of 4,642
SilverEars
Yeah, I just saw it. The most conductive one is $100. That's not cheap.
post-14958362
Post #1,466 of 4,642
snip3r77
why are some cables that we purchase is 'longer' than stock.
I actually prefer stock length
post-14958364
Post #1,467 of 4,642
Slater
That’s why I just get a good cable in the $15-$30 range and be done with it. I will never hear the extra 0.00000000001% improvement a $100 cable will provide anyways. Why? Because most of my IEMs are budget IEMs, and a $100 cable isn’t going to perform or sound any better on a $25 KZ than a $20 cable.
post-14958380
Post #1,468 of 4,642
hakuzen
using aliexpress coupons plus seller discount, i paid $68 for last one. recently, using May ae coupon ($5), final price was around $60. just search for the better deals.
there are also very low resistance cables for $16, like 065 and 053. although quality of the wire is worse than more expensive ones, and the sound with them is not so good. but, like @Slater has mentioned, you won't notice difference when using not very resolving iems, or small sound difference could not justify price difference for you.
Reactions: Slater
post-14958390
Post #1,469 of 4,642
hakuzen
yes, i think it cracked when pulling out from a cable. it's a vertical crack all height long, but the adapter is working perfectly. aesthetics issue. black ones are ok, although i've used them shorter.
i'd also go for penon ones. shorter length is a great advantage, and thinner pins can also be more versatile.
stock length is a bit short for me, when carrying the dap into my pocket (yep, i'm tall)
Reactions: Slater
post-14958488
Post #1,470 of 4,642
Linkoiram
US
US
Is this the right place to ask this? I need a usb c to 3.5mm adapter for my phone and it appears there aren't many good options out there. I thought they were all the same, but today I discovered the left and right audio channels were swapped on my cheapo chinese adapter and I realized I need to keep a stock of ones that work correctly. Moto z3 play so I'm not limited by the dac requirement that Google pixel phones have
Users Who Are Viewing This Thread (Users: 15, Guests: 13)
