Low end. Cheap. Generic. Otherwise bang for buck cable thread!
post-14953505
Post #1,441 of 4,676
Broquen
Barcelona, Catalonia
Age
46
this can be a real deal for single crystal silver cable. i'll get one when at sales for sure
I purchased B version some weeks ago (short one) and don't like the SQ compared to other cheaper ones. Maybe C version is better.
post-14953584
Post #1,442 of 4,676
hakuzen
The marketing blurb seems more on the mark than any other cable’s description I have seen.
Certainly has my attention.
Would love @hakuzen to put it through comparison against his top current favourites.
The seller also does UPOCC Litz version at only extra $10. The description for it is different though without the same marketing blurb.
4Core Upgraded Copper Cable lizt 3.5/2.5/4.4mm Earphone Cable MMCX 2PIN
https://s.click.aliexpress.com/e/cjgfcurA
quality of wire is similar to 165. in fact, found the wire used in 165 at this shop. 165 is my fav in terms of sound.
they also have a 8 cores (28awg) cable, 25awg/signal for 148€. would love to see more 8 cores cables using this kind of wire
Reactions: archy121
post-14953601
Post #1,443 of 4,676
hakuzen
are B or C version single crystal silver? D version is
post-14953639
Post #1,444 of 4,676
Broquen
Age
46
Both of them (B and C) are advised at FiiO site as single cristal or monocristaline as they call it.
post-14953721
Post #1,445 of 4,676
hakuzen
B and C are silver PLATED copper. D is pure single crystal silver, no copper inside
Reactions: Broquen
post-14953746
Post #1,446 of 4,676
Broquen
Age
46
Yes, my bad. Did not pay attention to cable material (assumed that material was silver plated copper too). Waiting to read impressions, then :)
post-14953925
Post #1,447 of 4,676
rbf1138
Can anyone recommend inexpensive, reputable/reliable replacement cables that will support the LS200/A2DC? I don't really like the material of the stock cables or the memory wire they have. I'd much prefer a lightweight cable. Thanks!
post-14954181
Post #1,448 of 4,676
subwoof3r
France
France
Hey everyone. Just wanted to share my solution for "improving" the strain relief on my cable 125. Basically, we used Heat-shrink tubing (huge thanks goes to my friend S.). It's the best possible approach/solution IMO, so here it goes:
The size of the tube we used is 8mm (we have all kinds of sizes), and we stretched it a bit with our Long-Nose Plier, so it can pass through the jack:
We used 2 pieces, one shorter below on top of the original strain-relief, and one longer on top, just in case. It's very sturdy, and looks nice with black tube, but more importantly, it does the job, and I'm no longer worried. We measured the cable (with and without adapter) and everything is as it should be. All connections are bellow 0.1 Ohms, so no bad/broken solders on my unit. Cheers. :)
Nice tip! thanks for sharing
According to your tutorial, I just made that to my 125 too. Very pleased with the result :)
Looks definitely more sturdy and feeling a bit less anxious now ^^
post-14954977
Post #1,449 of 4,676
Hal Rockwell
Israel
Israel
Age
37
I'm looking for a ready made Y-Split bulk cable, to recable my Takstar HF580. I rather it'll have a 3.5mm plug already soldered to it, but it's not a deal breaker - I can solder one myself. Has anyone seen something like this for sale?
post-14956485
Post #1,450 of 4,676
vurtomatic
Hi @hakuzen , I'm in the market for a cable for my 64 Audio Quad driver custom IEM. I saw your list but since the 165 is only available with MMCX connectors, can you recommend a cable with 2-pin connectors for recessed sockets?
post-14956731
Post #1,452 of 4,676
hakuzen
cable 125 is very decent, specially if you need to keep resistance low. it uses protruding 2pins plugs.
sound with 165 impressed me, despite of its resistance.
@subwoof3r found cables with similar wire (same manufacturer, taiwan, neotech? up-occ) and 2pins for recessed sockets available at a recent shop in ae.. they are 28awg (expect 300mOhm resistance, a bit high for my taste).
https://www.aliexpress.com/item/-/32999961682.html (no litz version)
https://www.aliexpress.com/item/-/1000007909452.html (litz version, even better probably, darker background) cable 170 (new) in my list (i've just ordered one).
anyway, you might wait a bit, to see if more cables using that kind of wire and 2pins plugs start to show in ae, or to take advantage of ae coupons during sales.
post-14956757
Post #1,453 of 4,676
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Estonia
Estonia
Question - does that cable impress You mostly with Moondrop Blessing or with all the other IEMs too (with what You can use it)?
Why I`m asking, is that I think impedance "match" with IEM impedance could be the case and with some other IEM this cable could not give so good result.
post-14956946
Post #1,454 of 4,676
hakuzen
it impressed me with blessing. blessing impedance is constant (20Ω, dynamic driver) till near 1kHz; ~22Ω at 1kHz; it reaches 27Ω at 2.5kHz and 8kHz; and goes down to 13Ω at 20kHz.
blessing is not so critical as other iems, like, for example, kz zs5v1 (4.5Ω).
i'd wish lower cable resistance, of course (the lower, the better), but sound was so clean that i even decided to order a 28awg (thinner) litz version (cable 170).
tried tenhz p4 pro with 165, and also got impressed.. p4 never sounded so well. will keep testing 165 with other iems.
the seller of cable 170 had an 8 cores version of silver plated 7n up-occ, no litz, in his shop. but now it isn't available.
asked the seller for 8 cores version cables which use 28awg litz. he has answered they'll offer them as soon as possible.
post-14956967
Post #1,455 of 4,676
Slater
Cincinnati, Ohio USA
That is a good point.
I have seen IEMs where the manufacturer specifically states that they include a cable of a certain impedance as part of the tuning.
I can’t remember an example off the top of my head though.
Reactions: CoiL
Users Who Are Viewing This Thread (Users: 1, Guests: 20)
