Low end. Cheap. Generic. Otherwise bang for buck cable thread!
75 76 77 78 79 80 81 82 83 84
86 87 88 89 90 91 92 93 94 95
  1. Jstew622
    Think this cable would be better than the ISN s8 for the BGVP Dm6?
  2. hakuzen
    thanks for the review! i find cable 125 exactly as you describe, and also its pros and cons. glad you appreciate it like i do =)
    thanks, glad you appreciate it like i do =)
    warriorpoet likes this.
  3. Richsvt
    I like the look of the conversion connectors, seems like a good cheap alternative. I wonder if these generate any noise, at least a perceivable type...for the money, I think I might try it out...
    courierdriver likes this.
  4. Dsnuts Contributor
    I think those adaptors will be more convienient for guys that have too much of one type of cable, for me mmcx and not enough of the others, 2 pin. Case in point. I recently got my MassDrop EE colab Zeus which is thus far is a great sounding iem but I would like to try out some of my nicer mmcx cables. Even though the Zeus is a 2 pin. These adaptors will let me try out my nicer mmcx cables on the Zeus so I can order an appropriate 2 pin set to go with my Zeus. For $20 spot these will come in handy.
    courierdriver, fokta and hakuzen like this.
  5. hakuzen
    didn't notice any noise.. their resistance is around 1 to 2 mOhm. short and well soldered.
    same here, to fit many mmcx cables into flc8s or moondrop blessing, in my case. these adapters are a great solution, they are the shortest i've seen
  6. eponies54
  7. Knightsfan11
    Any recommendations for the Weston W30 IEM's? Looking for a more durable cable, which won't effect the sound. If it can enhance it, even better.
  8. Palash
    Offtopic
    Commonly used adapters.
    8 shares 19 core ,10 cm, SPC cable. Gold-plated Plug and beautiful blue Aluminum alloy shell. Penon hi-fi adapters Just awesome. Well built too.
    My 2.5 mm balanced male to 3.5 mm balanced female adapter,
    3.5 mm balanced male to 2.5 mm balanced female,
    2.5 mm balanced male to 4.4 mm balanced female,
    3.5 mm balanced male to 4.4 mm balanced female,
    4.4 mm balanced male to 2.5 mm balanced female,
    and finally 3.5 single ended male to 2.5 mm balanced female.
    alexh, candlejack, hakuzen and 3 others like this.
  9. fokta
    was stuck in a very bad traffic... and doing cable swapping between 130 and Abnormal...
    the source, N5iiS with Amp E12a + cable swapping and Solaris...
    find that 130 give more dynamic, with Daff punk flac 24 bit Album Random Access Memory, Man, I will choose 130 all the way... it seems the cable need proper combo of amp to get its truth characters... @Dsnuts and @hakuzen, this is the best cable point out I have decide...
    Even my Abnormal only shine when it plugs direct to DAP...
    alexh and hakuzen like this.
  10. candlejack
    Meanwhile, my Acrolink 16 core SPC has been stuck at local customs for a week now... FFS!!! Don't these people know what's at stake here?!?!
    superuser1 and fokta like this.
  11. BobSmith8901
    Amazing, Palash, you've really got all contingencies covered with those adapters! Beautiful too!
    Palash likes this.
  12. keoki
    sorry but I have a noob question....I see everyone referencing to cable 125, 135, etc. anyone have a link of purchase or what should I be searching for? Whats the differences? sorry for the inexperienced question.
  13. Dani157
    Has anyone tried the new TRN 6 core cables for $6.5?
  14. bk123
    Just go through this post: https://www.head-fi.org/threads/low...uck-cable-thread.891911/page-19#post-14637360 of @hakuzen and you will get answer of all your queries.
    A big thank you to @hakuzen for such a great work on educating us on these affordable cables.
    hakuzen and keoki like this.
  15. Slater
    They look nice, but I wonder what effect only having 1 ground wire has on the conductivity?
