Low end. Cheap. Generic. Otherwise bang for buck cable thread!
61 62 63 64 65 66 67 68 69 70
72 73 74 75 76 77 78 79 80 81
  1. rendyG
    Where did you find the 125 for $72?
    I have 2 of the OKCSC adapters, they are good for the price, I think they were even mesured by hakuzen.
    However one of the three was wired out of phase so I asked for a replacement, so be aware :D
    Looks like I´ll pick the 130 then, or the 125 (if there is still some good deal on it).
    SPC seems like a better choice for someone who wants to tame the bass/lift some treble detail, but it can hurt (like with the DM6 :D). So far SPC works only on my FH5, it makes it bass less thick.
    Thank you guys, you are really helpful :)
  2. hakuzen
  3. perfecious
    It was the cheapest price I could find (the AK store) through mobile (mobile orders have additional discounts), +$10 worth of coupons. Send me a PM, and I will send you links if you want. :)
    rendyG likes this.
  4. hakuzen
    1st one works as you intend.
    2nd one, i'd bet it's 3.5 male TRS to 2.5 female TRS (single end), so it won't work
  5. perfecious
    You are right. If the female part/plug is 4 poles, I will re-solder it properly (it looks openable), using that ofc:
    [​IMG]
    I've also ordered one of these (which I would assume have the 4 poles) as well,
    [​IMG]
    that I intend on opening and resoldering. It's just in case the OKCSC proper adapter is wired wrong, and I can't open it. I hope it doesn't come to that of course :ksc75smile:, but those cheap ones are as a DIY back up in a way.
    hakuzen likes this.
  6. Plej
    Hi guys :wink: Thread is awesome, a lot of information here. I need 2.5 balanced cable for my andromedas (mmcx), it will be paired with radsone es100. Any suggestions? I'd like to achieve spacious and detailed sound. Lows are almost perfect for my taste and I don't want to bump sub/mid bass or make andro sound muddy. Can you recommend something? I was thinking about these two but maybe you can suggest something better.
    1. https://penonaudio.com/isn-audio-s16.html
    2. https://penonaudio.com/accessories/earphone-cable/ibasso-cb12cb13.html
  7. Palash
    ISN S8 or Effect audio origin.
    Plej likes this.
  8. Plej
    Thanks Palash. I hope these cables will not make highs smoother? I don't want to do that, highs in andromeda are pretty smooth already.
  9. archy121
    That’s what I was thinking - that’s cable 130.
    Seems they have listed it twice with different pricing. I hope they are the Exact same cable quality and not different grades.
  10. perfecious
    I've noticed these "duplicates" with higher price tags (same items, 2 pages, different pricing) on some other cables as well, sometimes even from the same store. They could be doing something "funky" on purpose, I don't know. :ksc75smile:
  11. blacksesame
    can anyone comment on isn s8 vs the linsoul 7n occ pure silver 4c?
  12. zeppu08
  13. Palash
    I think ISN S8 is a better option.
    hakuzen likes this.
  14. blacksesame
    thanks . s8 it is
  15. KimChee
    Looks amazing and great price...I might get one for the heck of it...I’ve got an 8 core nicechk on my TF10 custom and it sounds good...I too wish they made an open ended headphone version
    Palash likes this.
