@hakuzen
Hey buddy,
So regardless of the measurements any recommendations for the upcoming sale ?
I was planning to get some 053 and 130, i might drop the 053 for now, so what else do you recommend beside 130 to try out from your collection ? Also what is your planned purchases too
I might try the moondrop crescent also this time, has a nice hype going on.
hey.
i've received cheap jc ally 4 thick cores dark blue cable. will add it to the list soon (cable 065).
superb conductivity (0.10mm*63*4c!) due to thickness; cheap plugs. it's cheap version of cable 125.
when doing ab with cable 130, i didn't like 065 at all at first minutes (lows degradation, forwarded mids and highs, too bright and thin, not clean sound). i kept doing ab, and it happened like with isn audio cables: quite better result. 5-10 minutes is enough. although it can't be compared with 130 cleanliness. edit: once again, quality of conductor material matters.
have to do some more ab with other cables, but i can say they are good for the price they cost. pity the quality of plugs (same plugs than cheap trn cable, guess the difference of resistance between signals, which happens in both cables, is due to the jack solders).
there is something strange related to the used wire. advertised as 7n occ (obviously false) at lunashops, and 1m of single wire costs almost the same than 4*1.2m+plugs jc ally cable. or lunashops' wire is an scam, or jc ally has got tons of it very cheap.
i plan to get nicehck new 8 cores and 16 cores cables, spc and copper, to try them and compare with cables in that segment of price (053, 052, 065..).
and maybe the more expensive
https://www.aliexpress.com/item/-/32963189583.html , advertised as pure silver (which i doubt of); but i'm afraid it will be similar quality than cable 052 silver, which is cheaper. only way to know is purchasing it, but it's over $45, so dunno..
for quality high resolution iem, my recommendation is still the same: cables 130, 125, and 133 (these sales are a good chance to try 133 Gu's cables, they are not discounted frequently). 140, if you need a lighter thinner wire.
i ordered moondrop crescent last week. nice price for a supposedly well tuned dynamic driver.
