Low end. Cheap. Generic. Otherwise bang for buck cable thread!
222 223 224 225 226 227 228 229 230 231
233 234 235 236 237 238 239 240 241 242
  1. RikudouGoku
    in sweden they take that VAT + a constant fee of around 9 usd on ALL packages that comes outside EU. Super BS
  2. iron2k
    Yes they now charge taxes to US :frowning2:
    No taxes to Mexico but the postal service here isn't good so i prefer sending my stuff to USA
  3. subwoof3r
    Just bought 175 (4 cores version) and MMCX to 2Pin converter (but angled version this time) :)
    Wanted to pay with Paypal but always the same CSC error... so had to pay with credit card.. :/
    btw "friday10" was expired so I found another 10$ coupon, so if it can help try this one : "MAREDUC3"
    hakuzen likes this.
  4. hakuzen
    UP-OCC is one of the four certified OCC methods to make wire. made and patented by neotech (taiwan).
    cryo means the material gets frozen (cryogenic treatment) during a stage of the production.
    the goal of both is getting lower impurities, better aligned crystal boundaries, so the conductivity is improved in all parts of the conductor, for all frequencies.
    litz means the individual strands in each core are individually enameled (shielded). this helps to avoid oxidation.
    litz geometry means twisted strands, twisted groups of strands. different levels.
    litz shielding and geometry should help to decrease EMI noise and to decrease capacitance between conductors by adding more dielectric isolating layers.
    the effect on sound from the three methods is supposed to be:
    - deeper, wider, more three dimensional soundstage
    - lower noise floor
    - improved dynamic range
    - more articulate bass reproduction
    - smoother, more refined high frequency response
    my experience with up-occ wires has convinced me of these effects. others will tell you there are not differences.
    i'd go mixing up-occ pure silver with up-occ copper.
    neotech silver wire at authorized distributors is expensive. most aren't litz nor cryo, but use pvc or teflon sleeve (the latter adds stiffness, but has better dielectric properties). copper is also more expensive than other copper wires.
    oem up-occ wires are more affordable, most of them are cryo and litz, and use PE (polyethylene) sleeve. but you can't be sure they are made by neotech. my experience with these oem up-occ wires is very good, so i don't mind if neotech made them. to me, they are up-occ, notable difference with other wires i've tried (OCC / single crystal included).
    in the case you want to try oem up-occ wires, i recommend AgAu (silver 99% gold 1% alloy) for silver. for copper, cryo copper litz would be my preferred, but you need to remove litz from the wire between soldering on contacts (DIY), and this can be a bit annoying, so you could go for cryo copper no litz as well.
    zachmal, Krassi and RikudouGoku like this.
  5. saman65
    MAREDUC3 didn't work ;(
  6. progdvd
    Cable 175, any differences between standard color and blue other than cosmetic?
    Any pics of blue one?
    Also so far I didn't have a chance to check electro acousti cables I'm saving for 175 for my S8F. I'm wondering can anyone describe ear-hooks to me?
    As a reference my best cables I own are In terms of ear-hooks comfort best one I have is Gu.Craftsmans
    https://m.aliexpress.com/item/32982125051.html
    Perfect ear-hooks, very stable and comfortable. Not to thick cable, not heavy but just a tad hard.
    And cable wise softest and bendiest so to say my favourite cable to handle is Kingoofi
    https://m.aliexpress.com/item/32956046016.html
    Can anyone say what can I expect from electro acousti 175 cable compared to those two, in terms of earhook comfort, thickness, softness?
  7. muths66
    blue, brown only colour different.
    as for earhook i ok with electro one.i dun have much others
  8. Broquen
    LZ A6 is the most expensive, but it's a small package too. Hope there will be no problem. Plus I'm waiting for NCM Bella v1 from Vietnam in few weeks, and this is seriously more expensive. We'll see... (fingers crossed).
    Anyway, thanks for the input.
    superuser1 likes this.
  9. thi181
    I bought this cable from electro acousti with the 0.78mm 2-pins for my massdrop plus iems they sound great but the 2-pin cable gets removed quite easily which doesn't happen with other cables.
    I was looking to buy cable 175 but am now unsure of the 2-pin 078mm plugs from electro acousti are compatible with my Massdrop plus iems?
    Any info would be appreciated .
    https://nl.aliexpress.com/item/4000009633191.html?spm=a2g0s.9042311.0.0.63f64c4dn4ADA1
  10. muths66
    The below cable is the one you already bought from EA? If so you can ask them you having issue with the 2pins.
  11. Kenneth Galang
    At least two people posted pics in the last 5 pages (me incl)
  12. facethemusic88
    Should i bear in mind the awg for a particular wire? Wires in EA store come in varying awg. What difference does it make if any?
  13. Cevisi
    Delete
  14. Krassi
    Well seems the Chinese are on a revenge vendetta against USA.. F*U*C*K Trump for this..
    Well i dondt have anything from ali with Tax and i am german
    CoFire likes this.
  15. battosai
    You need an order of $120 or more
    saman65 likes this.
