Low end. Cheap. Generic. Otherwise bang for buck cable thread!
post-15256805
Post #2,896 of 4,006
fokta
Jakarta
Jakarta
Additional short Impression,
Been listening focusly between Local made OFC Copper 22 AWG, with 165 cable (UP-OCC Copper cyro 26AWG) ...
above : 165 ; Bottom : Local 22AWG OFC copper.
Conclusion... 165 still better, if you want a better separation between Mid Bass and Sub Bass, with additional better Upper Vocal/Mid.
While Local 22AWG, give you better Mid Bass only...
@hakuzen, yes, UPOCC is a good material cable.
That's my morning session in the weekend... my children have awaken, so back to reality
post-15256840
Post #2,897 of 4,006
superuser1
Sapta Sindhu
Sapta Sindhu
Why is this seller banned i bought the same cable from this seller and everthing was ok ?
You should read the link in @Slater sig to know the full story!
About DD Design adapter when testing with KXXS and NC5v2 i felt in comparison to the litz up-occ adapter the dynamism was less as well as the top end sparkle. Maybe my ears are effed up but that's what i hear. Also tried with King Pro and the same results. I must add that DD in comparison to fiio and ibasso adapters don't sound that much different. Also i think they are beautiful looking and have a great design.
post-15258197
Post #2,898 of 4,006
hakuzen
yea, that's another matter: material quality of wire and solders. if possible, i also prefer up-occ wire and silver solders, although it is 1-1.5cm.
i'm using some balun adapters for measuring and, although two baluns resistance is lower than 15mOhm, i wouldn't use them for listening to music. the short wire inside is not good quality
Reactions: superuser1
post-15258496
Post #2,899 of 4,006
hakuzen
If we look into any circuit board, we can see much more thinner tracks from amp chip to the 3.5 mm socket. When the length of the track or cable is short the thickness of the connecting cable or ribbon doesn't really matters.
from 4:00..
if you can do it, better use a point to point good quality wire, rather than a thin track on PCB. it will sound better surely. if you use the track, try to use the best and thickest copper you can. i'm afraid the tracks in the DD adapter are not so good. but hey, the look and form factor is great.
Reactions: fokta
post-15258826
Post #2,900 of 4,006
Palash
India
India
Website
www.audioglorye.com
from 4:00..
Cable instead of PCB is a ridiculous idea. With this theory audio circuit with through the hole component should sound better than SMD component. Don't want to break one of them, otherwise i would surely opened and measured the ribbon too.
Reactions: bobbooo
post-15259464
Post #2,901 of 4,006
hakuzen
of course it's a ridiculous idea when making hundreds of tiny amplifiers. prone to more errors, etc.
but PCB tracks into an adapter???
it's not needed you break the adapter to measure, you can trust my measurements
Reactions: fokta and Palash
post-15259644
Post #2,902 of 4,006
subwoof3r
France
France
Do someone please have a recommendation on where to buy a good 2Pin to MMCX adapter ?
I would like to try all my MMCX cables into 2Pin socket from my IEM (NiceHCK DB3), if possible
*edit* : I found THIS, but isn't it a bit expensive?
post-15259682
Post #2,903 of 4,006
Palash
India
India
Website
www.audioglorye.com
post-15260236
Post #2,904 of 4,006
thi181
I am looking for a cable for my massdrop plus for under €100 does someone have a recommendation for a good cable ?
post-15260613
Post #2,905 of 4,006
hakuzen
these adapters
the one suggested by Palash is the best price decent adapter, it's lower than half usual price for that adapter. guess it's the first time i see a reasonable price for these kind of adapters.
if you prefer angled adapter or higher quality overall, these have very good quality: egger hard resin, thicker and more durable than the plastic of cheaper adapters, gold plated copper contacts, silver solder.
https://www.aliexpress.com/item/32987522204.html
but $60!??
you can find them at various shops of taobao for around $20 (+agent's cut + shipping costs)
post-15261151
Post #2,906 of 4,006
bobbooo
I don't think anyone doubts your measurements. What we should all doubt however, are claims made by Paul McGowan of PS Audio, who you linked to in that video. This is a man who has said that there can be differences in the signal transmission of cables that are not electrical, see here:
What does he think carries the signal down a wire apart from electrons? Magical fairy dust? He's either completely deluded, or more likely, is peddling this nonsense in order to market snake oil products, such as his $1200 2-meter power cord (https://www.thecableco.com/perfectwave-ac-12-power-cord.html) with Premium Audiophile features such as "rectangular conductors for midrange performance". It's just utter nonsense.
When we look at sources of information, we should always first ask ourselves, could this person gain (or lose) by presenting (or denying) the particular claim in question. If the answer is yes (as it is in this case), this source cannot be fully trusted, without at the very least corroboration from other sources with no vested interest in the area.
post-15261288
Post #2,907 of 4,006
tiamor988
Malaysia
Malaysia
these adapters
the one suggested by Palash is the best price decent adapter, it's lower than half cost than usual price for that adapter. guess it's the first time i see a reasonable price for these kind of adapters.
but $60!??
Can you give the link for searches in taobao. I cannot speak or write in Chinese. I search with no luck.
post-15261317
Post #2,908 of 4,006
subwoof3r
France
France
these adapters
but $60!??
Many thanks for your recommendations,
Angled should be nice since I will use it for IEMs but the 60$ price is just crazy.. :D I was angry with electro acousti store so not sure I should buy from this store again but the price is really tempting. I will see then :) many thanks again
post-15261386
Post #2,909 of 4,006
SinisterDev
United States
United States
Lol. I know this is DEFINITELY not a bang-for-your-buck cable, but I was shopping around for one and came across this brand I've never seen before.... Are my eyes deceiving me, or is this really a $7,000 cable?!
https://s.click.aliexpress.com/e/edta06la
Reactions: zachmal
post-15261399
Post #2,910 of 4,006
hakuzen
search for "mmcx 0.78", it works
Reactions: tiamor988
Users Who Are Viewing This Thread (Users: 2, Guests: 5)
