RikudouGoku
Member of the Trade: RikuBuds
Ok Now I will not worry about T800 and M11, But are all MMCX cables compatible with all MMCX iems? Like are there something like KZs 2 pin standards with A,B and C?
the new Empire Ears Wraith is 4ohms, i guess no one should buy that9 is almost twice less than 16, so clipping and distortions above the design current/power should be an issue. I think I've seen few DAPs specified for 8 Ohm (Teac - HA-P90SD) that may be a safer and more empowering route.
Unless one have a source that is designed to properly handle them or plan to use them at moderate powerthe new Empire Ears Wraith is 4ohms, i guess no one should buy that
i just read the review, it hiss with everything and the price is 3499$, good dealUnless one have a source that is designed to properly handle them or plan to use them at moderate power
It can be a bit akin to buying a sports car with a speed limiter at 50 mph.
At least one can still accelerate with fun and make all the noise
it looks like the wire used in trn 8 cores cables.Got myself a new 8 core cable for approx $11 and got the following measurements - L+ 240 mOhm, R+ 240 mOhm, L- 120 mOhm, and R- 120 mOhm. Note these measurements are +/- 10 mOhm as that's the resolution of my meter...
Enclosed is a picture of the cable... Can anyone guess what it is?
the big difference between positive and ground measurements can only be explained by two possible causes:
a) wires (black and transparent sleeved) are different, one of them (used for ground) having double conductivity than the wire used for positive signals
b) all wires are the same, despite of different sleeve, but one core of each positive contact is not soldered (either in jack, either in 2pins plugs, either in both), while both 2 cores are soldered in ground contacts
b cause would match the solder issues found in trn 8 cores cables
then you could get even measurements after unsoldering all plugs, and re-soldering one transparent core and one black core to each contact. much work, and your actual measurements shouldn't cause any sound issue
170/171 mmcx plugs are all straight.@hakuzen do you have any link to a pure copper upocc litz with straight mmcx plugs? I've taken a look to your list and all I can see (170/171) are angled if I didn't see wrong.
I'm thinking about buy one (but maybe I'll wait until August sale).
BTW today got NiceHCK 8 cores ~10$ copper one to work and tbh the sound is pretty good (didn't like it much at first). The point is I prefer the cymbals tone of the pure copper with NC5v2 than mixed one (though it affects to all frequencies, not only highs) and am looking for same SQ of litz one, but with pure copper signature. In addition, the mixed cable I own is a balanced one, so need to use an adaptor to 3.5mm. single ended (which is good regarding quality, but uses silver plated copper -and affects sound anyways-).
Wanted to comment that I've noticed very clear the background noise increase with NiceHCK cable (that in the other hand is already good enough for the cost), plus a little (but perceptible) decrease in dynamics when using low volumes that didn't notice it before.
you can choose from 2 or 3 types of mmcx plugs, but they all are straight.
you can ask for not molded ear guides (this way i can use them with headphones, using adapters).
don't apologize, no bother at all!Thanks. I think I ended up looking to some other product by mistake, because all were angled as the one I own. Sorry for bothering.
