loud buzzing noise when powered on
Nov 10, 2006 at 10:20 PM Post #2 of 9
Originally Posted by ssingh0
My mpx3 slam makes a fairly loud buzzing noise when it is powered up. It stays constant as long as it's on.
What's the cause...?
Sounds like a ground loop.
Nov 10, 2006 at 10:45 PM Post #3 of 9
What is a ground loop? I prob sound ignorant here, but isn't the buzzing what's regarded as a noise floor? My E500s buzz / hiss as does my surround sound connected to analog inputs.
An amp gets rid of the noise I've found
Nov 10, 2006 at 10:54 PM Post #4 of 9
The buzzing can be many things .... he wasnt specific .... and the noise can be external or internal.
ground loop ......
http://www.epanorama.net/documents/groundloop/
Nov 10, 2006 at 10:58 PM Post #5 of 9
the buzz i'm referring to isn't on the headphone end or in the signal chain. It comes from the amp itself. When I turn the amp on without headpphones on, the amp emits a buzzing sound. It's been like this ever since i got it, but i think with the new tubes you gave it's even louder. I think it comes from the rear next to where the power cord plugs in.
thanks
Nov 11, 2006 at 10:30 PM Post #8 of 9
IIRC, a ground loop sound should emanate from the speakers (or cans), a transformer hum comes from the amp itself. It can be remedied by a PS Audio humbuster, which removes some of the (DC?) current that causes the transformers to vibrate. I'm doing this from memory, and could be wrong, but I think this is the deal.
Go to this link at PS Audio and read about their UPC-200HB, and you can also try their troubleshooting guide to hums and buzzes.
http://psaudio.com/products/upchbmoreinfo.asp
- walk
Nov 12, 2006 at 4:29 AM Post #9 of 9
When I got my MPX3 SLAM, I had a buzz externally from the transformer and a buzz through headphones from a ground loop. I installed a "cheater" plug ($0.30 from a hardware store) between the AC outlet and the power cable, and the ground loop hum completely disappeared. I am leaving the "cheater" plug permanently installed. The externally heard transformer hum has diminished over time, but is still audible (not through headphones) within a couple of feet of the amp. I am not concerned by this and I think it is normal behavior. I hope this helps...
