Lotoo PAW S1 - Designed for HIFI on the go with Lotoo PAW quality and the first USB DAC-AMP with dual 3.5mm & 4.4mm output
Jul 26, 2020 at 11:34 PM Post #811 of 2,202
ayang02
Taipei, Taiwan
Really like that, for the same reason. Where did you get it? Can’t find it anywhere
I got this from a local store that carries Lotoo products. You can probably ask the store/website you got your S1 from, since this case is also a Lotoo product.
Oh and this case comes in three colors: orange, green, and black. Mine is black.
Jul 27, 2020 at 10:46 AM Post #813 of 2,202
jsmiller58
Down the rabbit hole
Not quite sure I understand the allure / utility of the leather case... I suppose it will protect the S1 if you keep it in a bag/pack while not using it. But the silicone case that some have been using seems to be good for that and has the benefit that it can be used when the S1 is in use. But anyway it is nice to see protective accessories for our audio tools!
Jul 27, 2020 at 11:25 AM Post #815 of 2,202
ayang02
Taipei, Taiwan
The difference for me is this carrying case can also store the Lotoo OTG cable. I actually have some other OTG cables that are better performers but unfortunately doesn’t fit this case due to their thicker/longer size. Now I wish for a bigger leather case so I can fit a S1 with a fitted silicone case in it plus my other thicker OTG cable. But for now, this case will work and I won’t forget about that OTG cable 😁
Jul 27, 2020 at 12:03 PM Post #816 of 2,202
The leather case is beautiful, but my silicone case is perfect for me. Is great and offer good protection.
No glove, no love :D
Jul 27, 2020 at 2:01 PM Post #817 of 2,202
Palash
India
ASIO4ALL V2 in foobar working nicely with PAW -S1 :gs1000smile:
Jul 28, 2020 at 1:21 PM Post #819 of 2,202
xkoo
France
does anyone have lotoo paw s1 connected to A&K SP1000 DAP?
Jul 28, 2020 at 4:01 PM Post #820 of 2,202
I was getting intermittent connection; I think SPK is more sensitive to extra current draw from its USB-C port.
Jul 29, 2020 at 5:07 PM Post #822 of 2,202
bluestorm1992
Michigan/Virginia
The case is now available at Musicteck for $25!
Jul 29, 2020 at 5:14 PM Post #823 of 2,202
Nostoi
Vienna
Jul 29, 2020 at 8:27 PM Post #825 of 2,202
bluestorm1992
Michigan/Virginia
