BruceBanner
- Mar 26, 2011
For the Lotoo PAW 5000 EQ:
- Press ATE/PMEQ button
- Rotate wheel and then press center button to scroll thru then select from ATE, PMEQ, PMEQ Off, or PMEQ Management
- Rotate wheel and then press center button to scroll thru then select from about 6 options including Dental (if you selected ATE) or about 12 options including 4 User EQs (if you selected PMEQ) - User EQs are settings of the parametric EQ you’ve set in advance via PMEQ Management
- EQ now in effect, but you’ll want to push another button to leave EQ mode.
Cool, that helps, thanks for that. So... in theory, could you navigate to point 4. and stay there, without leaving EQ mode, so that you can then toggle EQ mode quickly again if need be? I wouldn't care for example to see Album art or track details etc, if you could still change volume and skip track whilst remaining in EQ mode that would be acceptable (does the screen turn off)?
