Loss of sound from one side of my RE-0s
Jul 19, 2010 at 8:10 PM Post #2 of 6
TheGame21x
Detroit, MI
That's likely caused by a short somewhere in the cable. Is there anywhere it has been kinked or snagged?
Jul 19, 2010 at 8:59 PM Post #3 of 6
David58117
What tips are you using?
Does it happen when you move the cable, or when you touch the housing to re-adjust the fit in your ear?
Anyway, I've had it happen before due to tips.  I know it's definitely not a short because I could touch the wire without any problems - it just happened when I adjusted the fit.
Jul 19, 2010 at 11:58 PM Post #6 of 6
JxK
Send it back for a new one. If you're hard on your earphones, maybe get a refund and purchase something a little more robust in its place.
